cone air filter
cone air filter
what size diamter will fit the end of the maf housing, looking at bmc foam filters
Re: cone air filter
May as well just take disconnect the pipe and measure it mate?
Re: cone air filter
If its standard maf, its 70mm. If updated, you'll have to measure it yourself!
Re: cone air filter
is the standard one, thanks buddy saved me alot of time
Re: cone air filter
http://www.jsperformance.co.uk/accessor ... -neck.html
i have myself confused now, i think this is the one i should be getting to go on the end of the maf housing right?
Re: cone air filter
if the diamter of the maf housing is 70mm, then i would be right in getting the 73mm to fit over?
Re: cone air filter
Use a silicon piece as a reducer
Re: cone air filter
ordered a 70mm to a 73mm reducer so im on it! itg filter to be ordered soonish, thanks for the help guys!
Re: cone air filter
new question! secondary air hose, need a filter to go on there right? what will fit?
Re: cone air filter
look what i found by my back door!
Re: cone air filter
ITG sell a filter to go there
ebay ones are a gamble, my one didnt fit
Re: cone air filter
ive measured the internal diamter at about 24mm so i think i get a 25 mm and a bit of force might work...
