And the rear
I havent got a pic of the front from above as you cant see it because of the arch
Im thinking of just buying the 15mm spacers and hoping for the best
Are you not tempted to feed it direct from the front Grille mate? It can be done with a little work and the flow would be awesomedaz16v wrote:yea i'm gonna do it myself.It will go to the hole in the inner wing like the original did
Yeah,I suppose you are right! I will look into it when i get around to a trial fitting.6N2 GTI 00 wrote:Are you not tempted to feed it direct from the front Grille mate? It can be done with a little work and the flow would be awesomedaz16v wrote:yea i'm gonna do it myself.It will go to the hole in the inner wing like the original did
