polo 6n2 excessive fuel consumption
Hi just new to the forum and looking for some advice I have a 2000 6n2 1.4s the problems are as follows temp gauge goes up to normal then drops to 0 ,engine cuts out at junctions when engine is warm, excessive fuel consumption down to as little as 19 MPG! Any ideas would be much appreciated
Re: polo 6n2 excessive fuel consumption
Your coolant temperature sensor has failed - get it changed and the problem should go away
Thanks Alex Perkins all get it changed as soon as, its driving me nut's is this a common problem?
This X2alexperkins wrote:Your coolant temperature sensor has failed - get it changed and the problem should go away
