Sourcing VW Polo mud flaps on-line
Golemsmate
Post by Golemsmate »
I've decided that I would quite like some genuine VW mud flaps for my polo. With the car I got an accessories booklet & it says the part numbers for mud flaps are 6R0 075 116 and 6R0 075 106and cost £128 for them to be fitted at the dealership. Is there any places on-line that sells the same part numbers? On eBay I have found "genuine" polo mk6 mud flaps but the part numbers 6R0 075 111 and 6R0 075 101, so I assume they differ to what the booklet recommends?
I'm hoping somebody has already tried to fit them after buying the car and might be able to help!
alexperkins
Site Admin
Re: Sourcing VW Polo mud flaps on-line
Post by alexperkins »
The part numbers will be different depending on what bumper/sills your polo has
Its important to get the right ones or they wont fit properly.
Beerbelly
Post by Beerbelly »
If you take my advice try to get the shorter versions. I've got the long ones and they catch on obstacles on the road very easily, such as dropping off a very small kerb, it sounds like the bottom of the car is being ripped off!
Golemsmate
@beerbelly is there any way to find out if the 101 or 116 part numbers are the long and short?
These are the ones I saw on eBay, I'm going to say these are long?
http://www.ebay.co.uk/itm/MUD-FLAPS-fro ... 0968947898
Beerbelly
Post by Beerbelly »
Those are the long ones, same as mine. I guess you can always trim them down a bit if you find them annoying.
Kalle
Drives: Polo 6R 2015 TSI 1,2 90 hp
Post by Kalle »
Hey,
Did you get the short ones and what part numbers was the right ones? Where did you order them? Was easy to install? And finally, did you become satisfied with the result?
Excuse many questions.... =)
Karl
Sweden
Mayhem
Drives: 2010 polo 1.2 tsi
Post by Mayhem »
http://www.ebay.co.uk/itm/BRAND-NEW-GEN ... 4ada6483d4
There you go. Short version. I have these they are great
Kalle
Post by Kalle »
Thanks a lot Mayhem! It clearly states that these are short.
Do you also have REAR flaps? Is it for any use?
I also would like to hear if someone did mount the boxes under frontseats? My car doesnt have these and i am considering to install such. If its not too expensive and difficult to install.
Thanks in advance =)
Mayhem
Post by Mayhem »
Yeah I have front and rear. I find the polo gets dirty very quickly, especially its arse. Seem to have slowed down the dirt build up
zim
Drives: Polo 6C, 1.2 TSI 90
Post by zim »
Does mounting these require drilling any holes in the metal panel, or just in the plastic liner/panel on the inside of the wheel house? Not very keen on poking holes in my car :?
alexperkins
Site Admin
Just the plastic
zim
Post by zim »
Great! Thanks alexperkins for your quick reply. Think I'll order the short ones now :)
wolfie
Post by wolfie »
Same here, I didn't realise there were two versions when I bought mine (long) they are OK with most speed-bumps but they do catch the more severe ones, but only the one fitted to the front, rear are fine. They do the job of keeping crud off the car.
Long version
6R0075101 REAR
6R0075111 FRONT
£40 ish a pair from http://www.volkswagenpartsdirect.co.uk/ ... olo,b.html
Short version
REAR 6R0075106
FRONT 6R0075116
Complete set:-
http://www.ebay.co.uk/itm/like/BRAND-NE ... RTM1793693
zim
Post by zim »
Thanks wolfie. Speed bumps are pretty much all over the place where I live and those long mud flaps would probably take a beating. Some of the "bumps" are design to slow down tanks... :shock: So I'm glad I found out from this thread that there's a shorter version :)
cheba
Drives: Polo R WRC 2014
Post by cheba »
Note that the rear bumper is slightly different on a standard 6R and 6C. The shape of the lower part is slightly different. So ones made for 6R won't fit perfectly on a 6C. This was discussed on another forum, although the 6C owner said he went to the VW dealer and got his 6R flaps changed for the 6C version, so there should be a 6C version available too.
