cheap way to camber my 9n polo front and rear?
any ideas would b great cheers guys!
CAMBER!!!
Lucaio
Re: CAMBER!!!
Camber bolts on the fronts, and a few washers on the rears.
mark03polo9n
Re: CAMBER!!!
bit more specific please? as i thought front camber bolts (as in where strut fixes) was a fixed camber point and washers at the rear?
Re: CAMBER!!!
I bought some K-Mac Camber/Caster adjustable top mounts. Not cheap at £360.
Can change my camber is 60 seconds though
Re: CAMBER!!!
Interesting idea, that might work with the 6N cars but not with the 9N cars, similarly a few washer on the rear will not do much, that end needs a set of these tapered shim packs to "cant" the hub over a bit.Lucaio wrote:Camber bolts on the fronts, and a few washers on the rears.
