Hi guys
Got myself a mk4 288mm hubs, disks, calipers, carriers,etc..... and some braided VRS lines
The electrical ABS sensor connectors are different, is that just a cut connectors off and crimp job?
I know I have to swap ball joints over, anything else to watch for?
I have a 2008 Bluemotion 2.
288mm Brakes on a 9N3
- Ben90
- Drives: Olympian Blue Polo TDi Sport
Re: 288mm Brakes on a 9N3
I'm pretty sure you'll need new front hubs for a 258 to 288 conversion.
K.I.T.T.
- Platinum Member
- Drives: Bicycle
Golf Mk4 hub carriers? Didn't know they fit. I spent ages tracking down some Ibiza TDI 130 hub carriers...
Ash
Ash
Guys as I said in 1st post, I have 288mm golf mk4 hubs also!
Do you know of anyone doing this upgrade on a 9N polo, seems Im the only one.
K.I.T.T.
- Platinum Member
- Drives: Bicycle
My question was whether Golf Mk4 hub carriers would fit the Polo...
And I've had all the bits ready to bolt on (Ibiza Mk4 TDI130 hubs and 288mm calipers / carriers) for a while. Just need to get round to fitting them.
Ash
Ash
wheel bearings are totally different plus the drive shafts may not fit. I may have a ste up available once the better weather is in as I am putting my polo back to original spec and it has the correct hubs and calipers.
So can Mk4 Golf 288mm hubs/upright be straight swapped onto a Polo 9N? The pictures and part numbers on ETOS are very very similar for the Golf and Polo Gti
Did you get these fitted? Can get hold of a set of mk4 288mm hubs, discs, carriers etc ans wondering if they'll fit my 9n
