Year/Reg: 2003 '03'
Mileage: 90867
MOT: 7/6/13
Tax: 31/3/13
Good points:
1 lady owner from new. (Mrs fonzooorooo)
Service history:
Main dealer for 1st few years, then (good!) local garage till '09, then serviced by myself. (all receipts supplied)
All the usual 9n polo problem bits have been done! (front arm bushes, all coil packs, ECU temperature sender have all been replaced, along with front springs and a top mount within the last 12 months, ) A little further back in it's history, the throttle body's been replaced, headlights have been replaced to fix the intermittent dodgy indicator problem and the rear screen washer has had the repair kit fitted.
Has been totally reliable. Has NEVER failed to reach it's destination, and has been in daily use.
Excellent in the snow(!)
15" Sport wheels with matching set of Goodyears replacing the standard steels/trims
Genuine front and rear Team Heko wind deflectors.
Original VW BETA headunit supplied along with a decent CD player.
Bad points:
A few little dings and scratches.(9 year old daily car - nothing bad, except for the key mark pictured) All scratches have been touched in to prevent rusting though.
A bit of curbing on 1 wheel (like that when I got them - again, pictured)
Other:
A proper, clean, drive-away problem free used car.
Reason for sale is it's time for something different, so we've got a mk2 golf.
Ideally a cash only sale, unless you've got a B2 passat you fancy P/Xing, but may consider others, either fast and loud, or slow and cheap.
Pictures:
Curbing to wheel:
Key scratch to O/S/R door
Price: £2500
Contact details: John on 07816 171205 or PM on here.
