hello people,
i got my new wheels on last night. 8x18" Kahn RS-C with 215/35/18. the car now wanders off to the left all the time so i have to steer slightly right to get the car in a straight line.
i went back to the garage and they said that its not their fault and it "might" be the tracking that needs to be adjusted. booked in for next thursday
they said that my wheels point out the way and will wear out my tyres much quicker if i dont fix it. VW i know will tell me to "go away!" so im not going there at all.
are they talking pants? or is the £35 they going to charge me be worthwhile?
I was going to get those but I was told they would slow down my car a lot and mess up my steering. Thats why I havent got them but apparently its true what they said. Those alloys are bizz
nice 1 mate
are theyre any other problems that can cause the steering to pull to one side? i dont want to fork out £35 for tracking and then they tell me its not that!
hmm me thinks it might be tracking, me needs this done too, i have exactly the same problem as you and mine are vw wheels with the correct size tyres as well
Yes you need to adjust your tracking. A stock Polo has a very neutral setup.
With small tires you won't have a problem. But now with the big tires the wheels wander of the straight line on every hole you encounter.
I asked my profile-tyrecenter to adjust my setup to 1,5 degree toe-out.
It has been a big improvement which I would recommend also to people with stock-wheels. The car is much more stable in a straight line, the steering wheel is heavier and spins back to neutral faster.
A little bit of advice dont believe a word anybody says to you at Crow Road from the girls at reception right up to the general manager ( Arnold's son ) .
This sounds like Tramlining - used to happen loads on my old mk4. Its when car follows the grooves in the road - very scary in the wet as you'll find you have hardly any grip at all.
Normally its caused by wide(r) wheels with a smaller profile but can be caused if your wheels weren't balanced when the tyres were fitted.
£35 is not much to get it tested when ignoring it could cost you a lot more
you should be able to get laser tracking done for 20 quid if you look around.
get it done - improper tracking will cause wear NOT to mention awful handling! I lowered my polo and proper tracking caused me to get about twice as much grip from up front - not kidding!
Tracking CAN cause this to pull to the left - Kwik fit are talking sh1t.
my car was tracked by ATS and it pulls ever so slightly to the left if i let go. I'm keeping an eye on the tyre wear too but have driven polos that never pull to the left, so wasn't too impressed with ATS to be honest.
