Porsche Wheel Fitment
Match
Post by Match »
Looking at some Boxster twists which are a follows:
Front: 17x7 ET55, tyres are 205/50/17
Rear: 17x8.5 (is this 8j) ET50, tyres are 255/40/17 (why skinnier on the rear?)
I've tried www.willtheyfit.com a few times and I've worked out that I'll need 40mm adapters on the front and 60mm adapters on the rears... Is this right? I don't trust myself
Any help appreciated :)
C17LJR
Re: Porsche Wheel Fitment
Post by C17LJR »
Right, ill break it down a bit.
Fronts are 7" wide, you could go with a 195/40/17 on them, I'd go with a 25-30mm adapter
Rears are wider, (not skinnier?) 8.5" wide. 225/40/17 (or maybe 215s) will give a similar fit/shape to the fronts, for them, 30-35mm adapters, 40 at a push
Match
Post by Match »
C17LJR wrote:Right, ill break it down a bit.
I'm hesitant to take the tyres off as I'm on a tight budget, but I'll take this into consideration :)
Sorry I meant that the tyres on the rear are less deep (40 rather than the 50s on the front). May I ask how you worked out what adapters are needed? Thanks for breaking it down I'm a total newbie at this!
C17LJR
Post by C17LJR »
You'll never be able to use the standard Porsche size tyres mate, sorry. Your standard tyres (assuming they are 15") will be 185mm wide. That means if you were to use the Porsche rears you'd be using an extra 70mm tyre width.
Also remember, the middle part of a tyre size, (ie, the '40' on the rear you mention) this is height of the sidewall as a percentage of the width, so 40% of 255mm is 102mm sidewall height. This is the same as the front (50% of 205 = 102.5mm)
Hope this makes sense
Match
Post by Match »
C17LJR wrote:You'll never be able to use the standard Porsche size tyres mate, sorry. Your standard tyres (assuming they are 15") will be 185mm wide. That means if you were to use the Porsche rears you'd be using an extra 70mm tyre width.
Ohhhh I see! Thanks for the advice, you've helped a lot :D I was wondering, what about if I get a puncture and need to use my spare?
C17LJR
Post by C17LJR »
Rolling radius/circumference of a 15" wheel and a baloon tyre and a larger wheel with low profile tyre will be about the same so no issue using your standard spare.
Just make sure you carry your adapter 'tools' in the car so you can remove if required
Match
Post by Match »
C17LJR wrote:Rolling radius/circumference of a 15" wheel and a baloon tyre and a larger wheel with low profile tyre will be about the same so no issue using your standard spare.
Lovely, cheers :wink:
bambaaaa
Post by bambaaaa »
just go for the same set up as mine but id advise 30 mm adaptors rather than 35 mm
Match
Post by Match »
bambaaaa wrote:just go for the same set up as mine but id advise 30 mm adaptors rather than 35 mm
Yeah it makes sense as they're the same wheels, by the way are these the right adapters? Then 25mm also? http://bit.ly/ZmPXYD
B1N9S
Post by B1N9S »
If you use 30mm adapters, you will be reducing the offset to 20mm. Which will mean the wheels will be sticking out past the arch. I have wheels with 35mm offset and they are at the arch.
Personally, I would go for 15mm adapters (giving you a 35mm offset), but these are quite slim and doesn't give you much thread to secure the wheel. So I guess the choice is yours, maybe you should look for some wheels that go straight on.
The rear tyres are way to wide for your car. I think 215/40 are probably the largest to go for, they are standard fit to the 17" Boavistas, etc.
B1N9S
Post by B1N9S »
I think your talking b****x (no offence C17LJR). Where did you get that info ? My tyres are 215/35, so by your calcs, the sidewall is about 75mm - rubbish !! I always thought it was a direct measurement. i.e 215/40 (40mm sidewall) 215/35 (35mm sidewall), etc.
I mean just read what you have said. A 215/40 tyre will have a 102mm sidewall ???????? That's a 4 inch sidewall.
C17LJR
Post by C17LJR »
I think your talking ****** (no offence C17LJR). Where did you get that info ? My tyres are 215/35, so by your calcs, the sidewall is about 75mm - rubbish !! I always thought it was a direct measurement. i.e 215/40 (40mm sidewall) 215/35 (35mm sidewall), etc.
Woah there.
Think we need some clarification on this then.. Quick google search
http://www.tyreuk.com/help.html
http://www.audi-sport.net/vb/a4-a4-cabr ... ombos.html
http://www.v8register.net/articles/Tyre ... 1.7.08.pdf
C17LJR
Post by C17LJR »
Also, just realised the rears are a lower et to the front. I thought they were et55 too.
My final et on the wife's polo with the new wheels is 32 front and 27 rear which I'd say is spot on.
Thinking again, I'd do 25 front and 20 rear for adapters
Match
Post by Match »
C17LJR wrote:Also, just realised the rears are a lower et to the front. I thought they were et55 too.
Okay cheers, I'll keep an eye on this discussion anyway
Match
Post by Match »
B1N9S wrote:If you use 30mm adapters, you will be reducing the offset to 20mm. Which will mean the wheels will be sticking out past the arch. I have wheels with 35mm offset and they are at the arch.
It's a lot of effort to get these to fit I know but bambaaaa has done it. I would go for a set which fit directly but they're far more expensive than a used set of Porsche twists and the ones I'd like are simply out of my price range. Thanks for this advice though, I would have bought the wrong adapters otherwise!
Edit: mind you I just saw you sold a set of boavistas with tyres for £500?!
