Where to buy lambda/oxygen sensor
shawnged
Post by shawnged »
As titled for a 1.8 gti? Thanks for any help
rover220
Re: Where to buy lambda/oxygen sensor
Post by rover220 »
http://www.eurocarparts.com/ecp/c/Volks ... 114&000210
use brisk25 at checkout for 25% discount
Dom_
Post by Dom_ »
TPS for a genuine one
GSF or eurocarparts will probably do a Bosch one which is just as good as a genuine, the genuine is probably Bosch anyway
edit: Beaten to it!
shawnged
Post by shawnged »
Spot on people thanks! Purchased
shawnged
Post by shawnged »
Lambda sensor fitted exhaust light still on in car will i need to get this wiped with diagnostics?
Dom_
Post by Dom_ »
Yeah the code will need to be cleared using a diagnostic machine, or maybe disconnecting the battery overnight but this probably doesn't work on modern cars
shawnged
Post by shawnged »
Right hmm looks as though al have to pay the garage to clear it.
Dom_
Post by Dom_ »
Make sure there's no one on here local to you that has Vagcom :)
