melted spark plug
bambaaaa
melted spark plug
Post by bambaaaa »
has anyone ever heard of a spark plug melting itself into the head of the 1.4 tsi engine cause it has just happened to mine and i cannot understand how the engine could get so hot to do this while all temperature gauges were reading normal, i though it was just a coil away when it started miss-firing turns out the whole engine needs stripped and rebuilt(under warranty lucky ) if anyone knows anything about this i would love to hear
rover220
Re: melted spark plug
Post by rover220 »
Quite common to have bad plugs but not as extreme as your case. Vw fitted wrong plugs from factory. Plenty of threads on briskoda about this.
bambaaaa
Post by bambaaaa »
sorry its not melted into the head it has melted the end of and there is no compression in the bore
rover220
Post by rover220 »
yup, wrong plugs fitted by vw. read some threads on briskoda
