I got a genuine 9W7 bluetooth module and im very happy with it! So much better than that Bury crap I had.
I seen the air con knobs on this forum and decided to get them aswell. Think they look much better. Also got a black badge with red on the inside for the front.
It was my birthday last month and I got a private reg from my parents! So happy with it. I decided to order pressed plates and im so happy with them!
Hoping you can help, how did you do your front interior lights? Can't seem to get the dome off mine - feels like it will break! Also, do your LEDs stay on a little bit unless you turn them off completely? My interior rears and boot ones do.
Hi Thanks
To change the front interior lights you have to pull the whole unit out. Its tight to come out but it shouldnt break. Just need to pull hard enough haha. Ye the rear ones are on a bit when the front ones are but ive never checked the boot one. Dont think its a problem though. Hope this answers your questions
If you had the multi function steering wheel as an option, how come the car didn't come with the Bluetooth module, instead of the bury kit?
Your car looks good pal, first polo I have seen with the mudflaps. I ordered them to be fitted on my R Line but when it arrived at the dealers they couldn't fit them because of the side skirts and splitter that come standard lol
I dont know it just didnt haha. Thanks ye im getting the skirts put on so they will be coming off soon!
Hi mate. i have a black polo 6r, i love it also like some of the things you have done to yours.
Just a quick question about your pedals and footrest..are the pedals easy to install or do they require a bit of work? and have you just drilled the metal plate of the footrest on or did you remove the standard one?
peeetz wrote:Hi mate. i have a black polo 6r, i love it also like some of the things you have done to yours.
cheers.
Hi thanks To get the pedals on I put them in hot water to soften the rubber then it was quite easy. The footrest is a metal plate attached by screwes. I had to drill into the plastic of the footrest but the holes were already there on the metal part.
