Its as if its running out of petrol
jimbob
Post by jimbob »
when first starting my car in the morning and driving up my street my car seems to loose revs like when running out of petrol but by the time i reacht he end of the street it is back to normal. Has anyone else had this problem if so how did you overcome it
LogIK
Post by LogIK »
I used to have similar problems and also with starting. Turned out it was a bad connection of one of the vacuum pipes that go to the airbox.
What engine do you have?
Also, try cleaning out the throttle body with some carb cleaner, as I found this really helped when I had trouble with cold starts.
