coding
joelburbidge
coding
Post by joelburbidge »
im using a vcds to change some stuff on my polo and im struggling to do much i have a bluegt id like to put autolock and change the mfd to mph anyone done this?
NMavs
Re: coding
Post by NMavs »
Control module 09 - central convenience I think mate. Go into that, then select long coding, and go through each byte, their all named and listed and its just a matter of ticking the box and clicking apply.
Wilxay
coding
Post by Wilxay »
If his is blue gt is anything like my r line then long coding doesn't have any label files for him to see the bits names. The only thing I can do is go into instruments and go on adaptation. There is a lot of things you can change there like indicator celebration ;)
joelburbidge
Re: coding
When I've used vcds before they all have names on so simple do to, I've already done the needle celebration, and changed how the steering feels but other then that I'm lost, ill just have to keep playing with it
Wilxay
coding
Post by Wilxay »
How did you change the steering may I ask?
calvinw1
Re: coding
Post by calvinw1 »
Wilxay wrote:How did you change the steering may I ask?
Copied from another forum, however ;
STG 44 Steering Assistance
STG Codierung -> Channel 07
?xxxx: Airbag (See Notes!)
0 = Airbags not installed
1 = Airbags installed
x??xx: Steering Angle Sensor
01 = Steering Angle Sensor is Part of the Steering Aid
12 = Steering Angle Sensor is Part of the ABS/ESP
xxx??: Program Type
10 - Normal (9N: PR L05, L06, L07, L08, L19, L20, L21, L32, L33)
11 - Seat Ibiza (6J)
20 - Polo 9N GTI (PR G12)
21 - Seat Ibiza (6J)
30 - Comfort (Polo 6R Comfortline)
40 - Normal light vehicles (9N: PR L01, L02, L03, L04, L15, L16, L17, L18 )
41 - Skoda Fabia 2 RS / Polo GTI
50 - Comfort for light vehicles (Polo 6R Highline)
51 - Audi A1 (8X)
60 - Steering assistance for impaired (PR 1N5)
I've changed mine to 41, feels a lot better!
Wilxay
coding
Post by Wilxay »
That hasn't helped me much. Apart from knowing which program is which number. I can't get any information to which channels are which on the adaptation menu. Sorry to be asking questions on someone else's topic
alexperkins
Site Admin
Re: coding
Post by alexperkins »
The steering is controlled on Coding I and not adaptation
joelburbidge
Re: coding
I've now managed to sharpen up the brakes, I'm sure the blue gt is meant to have the xds system like the gti but the controllers not showing up
calvinw1
Re: coding
Post by calvinw1 »
How have you sharpened up the brakes? I found the xds on the r line and set it to strong, but couldn't find brakes?
joelburbidge
Re: coding
It's weird that you can find the xds and I can't it's in abs and I changed the hydraulic braking assistance to early and it's seemed to sharpen it up what release of vcds are you using? Also what else have you managed to do?
Wilxay
Re: coding
Post by Wilxay »
Has anyone found where the DRL channels are also the auto locking and unlocking features?
alexperkins
Site Admin
Re: coding
DRL channels to achieve what exactly?
Auto lock unlock should be under central convenience. I would think it's the same as the normal new polo with regard to location. You'll just have to do it on byte number if it's not in adaptation and is missing a label.
joelburbidge
Re: coding
Central conv isn't showing up as installed and when I try to make contact it can't contact it
alexperkins
Site Admin
Re: coding
What shows as installed - post up a scan
