Help removing inside boot trim?
calvinw1
Post by calvinw1 »
Hi trying to get access to the boot light. Probably easy, but it is seeming to be stuck behind the rear door cards and this is stopping it from coming out. Could someone please tell me the correct way to remove this piece of trim?
joelburbidge
Re: Help removing inside boot trim?
Post by joelburbidge »
you can just take the light cover off you know by put a screwdriver in where the little slot is
StreetTriple
Post by StreetTriple »
Your just showing off that your boot light is actually working :D
You can lever out the boot light with a screwdriver....but sort can't help if you want/need more removed...sorry!!
calvinw1
Post by calvinw1 »
Thanks ciclo! It sort of doesn't seem worth all that effort just to get a second light in the boot!
I edited the previous post with more links to the vw polo 2 doors.
A pleasure to help.
