Re: New Member. R-line 1.2 TSI 90hp 119gr.
Not mine. These are of a French forum mate.
Bought them here: http://www.ebay.de/itm/VW-Polo-6R-Ausse ... TQ:DE:1123
This is all the info that I know.
Edited ... Here there was links to videos that do not work.
Edit....next post...sorry.
New mod:
Auto folding mirrors system
With this module K418 and a relay JD1914 is not necessary to change the window regulator motor.
http://www.aliexpress.com/item/Side-vie ... 84519.html
This way only need to buy folding mirrors, module K418, switch, relay JD1914, wires, pins and cloth tape.
Window regulator motors are not necessary.
Wiring Diagram
Wiring diagrams oem:
T28a
Placement
Extractors terminals connectors.
http://cgi.ebay.es/ws/eBayISAPI.dll?Vie ... 1192966256
or:
Trimmed to remove to install the module auto folding mirrors K418.
Tools to remove trim.
With these tools is removed the door trim easily. Is inserted through the center of the fastener and this is released.
http://www.aliexpress.com/item/4PCS-Car ... 48088.html
Screws trim: Torx
Screw mirror: XZN
Switch and Folding mirrors.
Part Numbers. LHD, RHD
Click to enlarge
For example: To my r-line 4-Door with LHD.
OE-Nr: 6R1959565GREH
OE-Nr: 6R1857507R9B9
OE-Nr: 6R1857508R9B9
Link to buy the new switch and new folding mirrors.
http://www.carparts-pros.com/
I've changed the switch knob.
Must be put the glass and cap in the new folding mirrors from which we have as standard.
Such as:
https://www.youtube*.com/watch?v=xHDAMXYDPz0
Wiring.
To save window regulator motors need to link the two mirrors with wires to the control unit K418.
Passenger door
Same with the driver's door, adding a signal wire for folding mirrors from the switch connector T10K/8 to T28a/26 outside.
Installation scheme of the control unit K418.
I have placed folding mirrors fuse inside the fuse box and grounded on metal frame.
I have installed an T3 coupling for ease of installation.
T3
K418
Received. Inside, small checks, details, wiring preparation for installing the fuse in the fuse box.
Fitting the control unit K418.
Drill bit 8mm, expanding nuts, felt, screws, control unit.
K418, T28a, T3
The folding mirrors system works with the remote control correctly without installing the switch and the relay.
Acc on prevent the mirrors are folded If it is pressed on the central locking switch.
Relay JD1914 5-pin 12V changeover.
K418 module is designed to operate with positive signals from the switch.
Mirrors switch work by closing the circuit to ground therefore it is necessary to install a relay.
http://www.ebay.co.uk/itm/Automotive-5- ... 0995432573
Electrical circuit, terminal numbers, placement, wiring. Finished installation.
How it works:
-Acc - off:
1. Switch in folded position. The mirrors are folded . "The system is not enabled for remote control".
2. Switch in any other position. The mirrors are unfolded. The system will be enabled. The remote control can fold and unfold the mirrors.
-Acc-on:
1. Switch in folded position. The mirrors are folded. The system is not enabled. The mirrors will remain always folded.
2. Switch in any other position. The mirrors are unfolded. The system is not enabled. The remote control can not fold and unfold the mirrors.
-The switch can fold and unfold the mirrors at all times.
Extra video.
Safety switch for central locking on passenger door
http://www.uk-polos.net/view ... 75#p473025
Wiring Diagram
T28a
Placement
or:
Screws trim: Torx
Screw mirror: XZN
Click to enlarge
Such as:
Wiring.
Passenger door
T3
K418
K418, T28a, T3
How it works:
-Acc - off:
-Acc-on:
Extra video.
joelburbidge
i went into my vw dealers part dept yesterday and gave him the the part numbers and is all that they could find with them is a window motor is the correct part?
I suppose you have asked your dealer for a vehicle to RHD.
The reference numbers are from the online ETKA updated.
Here:
http://ifinterface.com/page/page3.php?langid=2
Click carprog2 - close dialog boxes - select language, etc. - for vw polo select PO - then looking for parts ...
In any case the reference numbers are correct.
Here:
joelburbidge
i literally just gave him all the numbers to try only a few of them worked if i order any of the parts i wont be able to return so i dont know whether its worth the risk i did message the person on ebay but i had no response
This is the cheapest place I've found for new parts. I've bought here and everything right.
I think in this case worth buying new parts. It's hard to find used parts in good condition for folding mirrors for vw polo 6R.
Edit:
To joelburbidge:
The video information is old.
The correct part numbers for folding mirrors for vw polo 6r with RHD are several post later. I assumed that you had read this information that I put to you (and now also for me) because you asked. I apologize if the video information (old) has created confusion.
I will delete the info of the video to avoid confusion.
Edit:
To joelburbidge:
Congratulations Ciclo for your car; it looks great and the mod's are the ones the car should had from VW.
Saludos desde Barcelona.
Thanks for your comment, I think for vw polo 2014 restyling will have more options.
As you can see I'm with the folding mirrors. I still have to get some parts so I guess that next week I will have finished with this mod.
Gràcies per utilitzar l'anglès per a tots.
Saludos.
Saludos.
A very interesting link of a Russian forum on vw polo sedan. Many interesting images, illustrative and amazing. I thank from here to the Russian mate publications.
http://www.drive2.ru/cars/volkswagen/po ... =asc#pager
I'm updating the installation of auto folding mirrors some previous posts and these images of Russian Forum help a lot.
New mod:
At the same time I'm doing the installation of the auto folding mirrors I made this new modification.
Parts
For RHD: 1K0972704G--6R0867171K82V--6R0867179JTLL--6R1962125AREH
Wiring diagram.
I have no good images, I hope these are useful.
It works perfectly.
There is interesting information (links, images, tools, etc ...) here:
http://www.uk-polos.net/view ... 61#p472068
Parts
Wiring diagram.
It works perfectly.
- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
I actually thought all Polo's came with that stock. But I guess not.
I guess Volkswagen saves manufacturing costs for competitive pricing of their cars.
