using logik's mk3 as an example, here is the radiator baffle, also insulationTahrey1043 wrote: not sure what you're on about with radiator baffles and all that!
i know you didnt mean the barry bit, i was pulling your leg matey
@groovy: as you have a carb you are lucky to be able to do a bolt on, i had this on my mk2. its much louder than the induction kit and on my weber setup it made a much bigger difference in torque than my induction kit. Bearing in mind we are comparing chalk with cheese between the mk2 and mk3.
