joelburbidge
ciclo how do you remove the panel under the steering wheel?
http://volkswagen.workshop-manuals.com/ ... php?id=993
You can remove the two covers without removing the steering wheel.
Here you have pictures that might help:
http://www.uk-polos.net/view ... 10&t=54171
joelburbidge
how did you gain access to the bcm?
https://www.youtube*.com/watch?feature=pl ... wb1iUPgnLA
https://www.youtube*.com/watch?feature=pl ... ZVuXxUOIzk
Was looking for a better video but now can not find. You have to rest your head in the zone of pedals and enter the arm to remove the connectors. Has certain difficulty by the reduced space.
Edit, these videos are for LHD. I guess for RHD will be similar.
Pearls
- Drives: Polo GTI 1.8TSI
This is the most impressive modified Polo I have seen. Well done, your work is really good! I wish Volkswagen's optional extras department employed you, they could do with a bit of creativity in their Polo range.
I think Ciclo only missed heating in seats.
Everything else seems done.
Pearls
Doubt he needs them in Spaingtblue wrote:I think Ciclo only missed heating in seats.
Thank you very much for your comment Pearls.
Indeed, where I live in Spain I do not need heated seats system. If I put the leather upholstery (in a couple of years) will probably install it.
Next mod that I have in mind is installing a gas spring for opening bonnet but take time to find the right parts.
Image electronic circuit auto folding mirrors k418 that I have found online.
http://www.uk-polos.net/view ... 75#p472068
- greypolo9n3
- Drives: white 6r 1.6 tdi rline/gti
Wow...you are the mod god! lol
Can you tell me where BCM is located?
do i need to change bcm for reverse camera, xenon LED headlights & cruise control / on board computer?
Also how do i remove DRL on vcds with standard halogen headlights?
"Thunderstruck" . You're the first person who notices that I am a god. Thks
. lolololololololololololololololol!!
We started:
First, music to awaken the mind while we take place in the Olympus (recommended up the volume to hear the neighbors
https://www.youtube.com/watch?v=fT330_kxJOE
Preamble:
If a question arises during the reading of this post probably you solve reading here:
http://workshop-manuals.com/
VW: http://volkswagen.workshop-manuals.com/
Polo Mk5: http://volkswagen.workshop-manuals.com/ ... x.php?id=4
Search, eg onboard unit J519 removing polo mk5: http://volkswagen.workshop-manuals.com/ ... hp?id=1451
BCM location (lhd): https://www.youtube*.com/watch?v=9yagbbCL ... r_embedded
That BCM requirements: (touches you translate German)
http://www.polo6rfreunde.de/board3-der- ... nen-im-6r/
http://www.polo6rfreunde.de/board3-der- ... 17a771ecce
To install the Rear View Camera need your radio navigation system has video input. Eg, RNS315, RNS510, RCD510 with plug 26-pin video. No need to change the bcm.
------------ deleted line---------------
To install the onboard computer need to do this: https://www.youtube*.com/watch?v=dVEIN7JC ... r_embedded
, but this you'd know if you were done a search in the forum. Cruise control is similar but more complex. In any case when you need electrical diagram you ask me.
To my knowledge, you can not disable the DRL via vcds. You have to bend the pin in the connector (T17) of the light switch.
Interesting web links:
http://www.carsystems.pl/volkswagen,c1.html
http://www.kufatec.de/shop/en/volkswagen/polo/polo-6r
There is a forum mate that makes these works (eddie-gt, sorry if I spelled wrong) but I do not know him.
To finish, the original Thunderstruck (let it rip).
https://www.youtube*.com/watch?v=ZtOpP4QJa9k
We started:
Preamble:
- greypolo9n3
how can i do full scan of BCM on vcds
Each time you make a Autoscan and you saved it is filed in the Logs folder.
- greypolo9n3
Right i see....thanks your great help!
can you get cruise control/DIS system from where you live cheap?
also cheap reverse cam?
The most competitive prices and good service for OEM parts are in the link given the post of music ...
eg:
http://www.kufatec.de/shop/en/Volkswage ... ction_ms=1
Remember to select the model year. As you can see in the link also tells you that it is necessary your BCM has to be at least 6R0 937 087 or higher.
http://www.carsystems.pl/vw-rear-emblem ... id691.html
This is the best price you can find for OEM RVC. Includes adapter before you can install.
In Spain it's all more expensive, abusive tax, "etc" ...
... I prefer not to comment on none of this.
Everyone knows that it is cheaper to buy in China.
I recommend you the links that I posted.
eg:
