Metallic black
Mot till 1st of jan, tax till feb 2014
56 plate
73,000 miles (will go up slightly)
Full service history, Cambelt done at 66,000 miles.
New radiator fitted as the one fitted was leaking.
Standard interior
Outside:
Lowered on JOM coilovers (not the best but its no track car to me) £180
Shortened drop links £30
Cupra bushes £25
Lower honeycomb grill centre
Antrachite and black badges
Engine:
Stage 3 jbs conversion costing £5.2k completed may 2013 at 69,500 miles consisting of:
Loba Motorsport l300 turbo with forge adjustable actuator £1550
Jbs high flow cast manifold £400
Bosch 4 bar fuel pump £287
Bosch 4 bar fuel regulator £87
Bosch 380cc injectors £450
Bosch 3" maf £186
Genuine PD160 air box to suit 3" maf £85
Green cotton panel filter £51
PD160 cold air intake £104
Forge custom TIP (to suit 3" maf and larger turbo inlet) £150
Forge FMIC £675
Custom code stage 3 mapping £550
Full service and check up at the same time 1,500 miles ago
Other odds and sods needed it all adds up
Plus labour on top
Plus:
Milltek 3" large bore decat down pipe £190
Milltek cat back non resonated £359
Forge 007p diverter valve £100
Odds:
Black coolant cap £10
Private plate T18 PVW £255
Autohaus Wolfsburg plate surrounds £15
Clutch is standard and coping extremely well
Only ever ran on v power
Brakes are also currently standard however done me ok with good pads.
All parts fitted have been brand new with no second hand parts fitted so this really has had no expense spared.
All standard parts i have such as suspension etc would be included in the sale.
NOW FOR THE BAD PARTS hence the price:
Abs and traction control light on dash, plugged into vagcom which comes up with abs pump failure or short circuit
Damage to passenger side wing mirror casing, mirror works fine still
Slight dent to wing
One front lower grill is missing (drivers side)
Viewing is recommended, test drives are welcome however must show proof of insurance with the mods declared other than that il do the driving
Car will come on standard monzas not on the schmidts in the pictures below.
I will place more pictures up over the weekend when I can get some in the light
Any questions please ask on here or text/call me on zero 79791 zero 3529
Price again is £6,500 Ono and located in Chatham, Kent
Thanks, andy
