Trying to remove 6n2 dash
- Rom Tasburn
Hi guys. I'm trying to get the dash out my 6n2 but it just won't budge I have undone the 4 bolts under the scuttle panel the t20s at the sides of the dash and have removed all the dash trim from underneath. Is there something I can't see?
Re: Trying to remove 6n2 dash
Removing the dash
WARNING Disconnect battery earth strap before working on electrical system.
– Remove steering wheel 10.99 ►
– Remove steering column switches and Steering column switches
– Remove driver side storage compartment 10.99 ►
– Remove centre console 10.99 ►
– Remove glove box 10.99 ►
– Remove bolt -1-.
– Unclip upper part of instrument trim panel -2- in -direction of arrow-.![Image](http://volkswagen.workshop-manuals.com/polo-mk3/images/polo-mk3-901.png)
– Remove three screws -arrows-.
– Remove instrument trim panel -1-.![Image](http://volkswagen.workshop-manuals.com/polo-mk3/images/polo-mk3-902.png)
– Remove two bolts -arrows-.
– Remove instrument cluster.
– Unplug connector.![Image](http://volkswagen.workshop-manuals.com/polo-mk3/images/polo-mk3-903.png)
– Unscrew hexagon nuts -arrows-.
Note - The two hexagon nuts are only visible when the instrument cluster is removed.![Image](http://volkswagen.workshop-manuals.com/polo-mk3/images/polo-mk3-904.png)
– Press in light switch -arrow-, turn to right and pull out.
– Unplug connector.![Image](http://volkswagen.workshop-manuals.com/polo-mk3/images/polo-mk3-905.png)
– Remove bolt -arrow-.
– Pull out driver's side vent -1-.
– Pull connector off headlight range control -2-.![Image](http://volkswagen.workshop-manuals.com/polo-mk3/images/polo-mk3-906.png)
– Remove bolts -1- and -2-.
– Separate cable ties -arrows-.![Image](http://volkswagen.workshop-manuals.com/polo-mk3/images/polo-mk3-907.png)
– Loosen left and right sill trim strips -1-.
– Remove bolt -2- on left and right.![Image](http://volkswagen.workshop-manuals.com/polo-mk3/images/polo-mk3-908.png)
– Unclip left and right covers -1-.
– Remove bolt -2- on left and right.![Image](http://volkswagen.workshop-manuals.com/polo-mk3/images/polo-mk3-909.png)
– Remove driver's footwell cover.![Image](http://volkswagen.workshop-manuals.com/polo-mk3/images/polo-mk3-910.png)
– Remove two screws -1-.
– Unscrew hexagon nut -2-.
– Remove support -3-.![Image](http://volkswagen.workshop-manuals.com/polo-mk3/images/polo-mk3-911.png)
– Insert radio release tool -T10057- into the release slots until they engage.
– Pull radio out of dash panel using grip rings of release tools and separate connectors.
Note
When doing this the radio release tool -T10057- must not be pushed to the side or tilted.
To remove release tools from radio, press locating lugs on sides of radio inwards.
– Pull out compartment -1-.![Image](http://volkswagen.workshop-manuals.com/polo-mk3/images/polo-mk3-912.png)
– Remove centre vent.
– Pull connector from hazard warning light switch.![Image](http://volkswagen.workshop-manuals.com/polo-mk3/images/polo-mk3-913.png)
Note - The screws can be seen through the apertures, and are set back by approx. 2 cm.![Image](http://volkswagen.workshop-manuals.com/polo-mk3/images/polo-mk3-914.png)
– Pull off rubber seal -1- upwards to centre of vehicle.
– Unclip plenum chamber cover -2--arrows- and pull out.![Image](http://volkswagen.workshop-manuals.com/polo-mk3/images/polo-mk3-915.png)
– Unclip pollen filter frame -1-.
– Remove pollen filter -2-.
– Unscrew hexagon nuts -3-.
– Remove pollen filter housing -4-.![Image](http://volkswagen.workshop-manuals.com/polo-mk3/images/polo-mk3-916.png)
– Remove four screws -arrows-.![Image](http://volkswagen.workshop-manuals.com/polo-mk3/images/polo-mk3-917.png)
– Pull dash panel forwards.
Note- The wiring harness is secured to the dash panel by clips and cable ties. The wiring harness remains in the vehicle when removing the dash panel.
– Loosen clips, disconnect cable ties and connectors depending on vehicle equipment.
– Lift out dash panel.![Image](http://volkswagen.workshop-manuals.com/polo-mk3/images/polo-mk3-918.png)
– Remove bolt -1-.
– Unplug connector.
– Unplug connector.
Note
- Rom Tasburn
You sir are a life saver! Thank you soo much ![Smile :)](./images/smilies/icon_smile.gif)
No problem
- Piers0930
Alex what program is that?
ElsaWIN - The VW official workshop manual system.
- Rom Tasburn
Ok so I haven't had much time recently but both tonight and last night I have attacked my dash, there is nothing holding it on but it seems to be holding on/pivoting on something at the top.....do I just have to man up and pull it really hard? I'm worried I'm going to break something!
As long as you do every step of the guide it should come out.
- Rom Tasburn
Yep problem sorted its louse just need to cut all the cable ties
thanks again!
any chance of getting these pics again? as having trouble getting the dash out ![Sad :(](./images/smilies/icon_sad.gif)
none of the pcs are showig just squares?
if you need a hand i know now cause i done it today
