With vcds 12.xx.x it are displayed on the dropdown panel, with vcds 11.11.3 is not indicated and we must find the Channels with up and down buttons.
The time is indicated in seconds and is possible until 60 sec. I finally got 25 sec for leaving home, 15 sec for coming home.
joelburbidge
i've sent you message ciclo but it doesnt seem to be going through is your inbox full?
PMjoelburbidge wrote:i've sent you message ciclo but it doesnt seem to be going through is your inbox full?
- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
looks awesome with the mirror's.
But the guide you have posted... WOW. I really don't wan't to get involved with that... Look's very complicatet.
Thanks Mart!n
. It is awesome and a nice upgrade of my wing mirrors.
The guide is how I've done. It can always be improved.
Small colored puzzle that stimulates the senses...
wooowwwww this look great but also lot of work !
I recommend it, it is very useful.
The work can be done gradually. First, a door, the next day another and so on.
I have news for your automatic lights and fog lights. Best I comment you by pm.
I will post here a wiring diagram, soon...I have to do some checking.
AUTOMATIC LIGHTS COMING HOME / LEAVING HOME
https://drive.google.com/file/d/0B2nv91 ... E1bk0/edit
eBay: Laser 3932 Terminal Tool
This "quote" is selling I had in this forum.
The reason for this "quote" is to keep the information here.
ciclo wrote:Description:
Automatic lights and functions coming/leaving home.
For all VW POLO 6R with factory xenon headlights + light sensor .
For all VW POLO 6R with halogen headlights + start/stop system + light sensor. Bluemotion.
Full Kit
+ VCDS coding
- Wiring 100% OEM. Brand new. Lifetime warranty in the wiring.
- One switch OEM. Brand new.
- Two universal relays. Brand new.
- Coding perfect through email. All lights will work correctly, same as factory.
110 € Included shipping and PayPal fees
Payment by PayPal
Shipping certified and tracking number. Shipping worldwide.
Installation Guide: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
Laser 3932 Terminal Tool: http://www.ebay.co.uk/sch/i.html?_from= ... ol&_sop=15
Features:
Automatic Light:
The main lights come on when the light threshold is appropriate.
Leaving Home:
Unlock the car with the remote control, then dipped beam (or fog lights), side lights, license plate lights come on for the set time.
Coming Home:
Turn off the ignition, then pull the high beam stalk once (flash), now when you open the door dipped beam (or fog lights), side lights, license plate lights come on for the set time.
Set time:
To change the set time is on channels 47 and 48 Adaptation or Adaptation UDS from the drop panel.
This can be up to 60 seconds, but I think it's best not to put more than 30 seconds, the battery will wear less.
http://www.uk-polos.net/view ... 05#p474349
Example of purchase order (thanks to teji-GTI):
Click to enlarge:
Sensitivity of light sensor OEM
"Simply perfect"
If the threshold of light decreases within the tunnel or during the day, activation is immediate.
The light threshold can be corrected with VCDS.
VIN http://en.wikipedia.org/wiki/Vehicle_id ... ion_number
I need to know the tenth letter of the VIN to send the correct wiring. This indicates the "Model Year".
For example:
WVWZZZ6RZDYXXXXXX
D = MODEL YEAR 2013
(A=2010, B=2011, C=2012, E=2014)
VIN you can find in a small window of the windshield, driver's door on B-pillar, or also in autoscan with VCDS.
What is the current situation with auto lights installed to car with xenons, rain sensor, start-stop and only rear foglight. Is the Kufatec kit still a valid option?
Referring to your post here:
http://www.uk-polos.net/view ... 68#p474168
What kind of problems this combination produces?
- Mart!n-GTI-DK
- Platinum Member
I have the kufatec kit installed. The only problem two problem I have had is that the High beams didn't work after install but was corrected with a bit of coding, And the rear foglight didn't work anymore. Couldn't get the foglught working so I bought a taillight with reverselight from a RHD model (mine is LHD) and I instead made reverselight on sides instead of the foglight which I have never in my life used anyway on any of my cars.matti wrote:What is the current situation with auto lights installed to car with xenons, rain sensor, start-stop and only rear foglight. Is the Kufatec kit still a valid option?
Here's the result:
This wouldn't be road legal. Is there any solution to keep rear foglight working? High beams are of course mandatory as during winter time 95% of driving happens at dark.Mart!n-GTI-DK wrote:I have the kufatec kit installed. The only problem two problem I have had is that the High beams didn't work after install but was corrected with a bit of coding, And the rear foglight didn't work anymore. Couldn't get the foglught working so I bought a taillight with reverselight from a RHD model (mine is LHD) and I instead made reverselight on sides instead of the foglight which I have never in my life used anyway on any of my cars.matti wrote:What is the current situation with auto lights installed to car with xenons, rain sensor, start-stop and only rear foglight. Is the Kufatec kit still a valid option?
- Mart!n-GTI-DK
- Platinum Member
From what I have read I don't think so no...matti wrote:This wouldn't be road legal. Is there any solution to keep rear foglight working?
matti, I have not the Kufatec wiring.
I did my wiring and now I'm going to redo as you see in the diagram.
How is your wiring different from Kufatec?ciclo wrote:matti, I have not the Kufatec wiring.
Also, what is causing the rear foglight issue? How is start-stop involved in this mess?
