will these fit 312mm brakes
Ive located a set of 312mm calipers n carriers of a 99 s3 will these fit on my 9n polo gt using original brake hoses n just simple bolt on? Thanks
Re: will these fit 312mm brakes
Why have u bumped my question?
Yes these will bolt on using the original brake lines absolutely fine. The hubs are the same on the gt and gtis so the upgrade is bolt on .
Rub em down slap em on cant wait thank you.
Will these go behind 16" steels (winters) 16" fabia vrs wheels?
Yes they'll go behind 16" wheels fine. I've got 16" winter wheels too and they look quite impressive as there's only a few mil clearance. Hope you get them sorted alright!
Yer braided hoses on route hoping to get em on at weekend. They look massive off car lol. What difference did u notice?
You don't need braided hoses but they'll certainly help. I noticed a massive difference after fitting mine but that was partially due to the pads on the old set up being worn down to metal! To get the best out of the bigger brakes, team them with oem discs and Ferodo DS2500, you'll be on to a winner then! What colour did you decide to paint them?
Thats the tough question I dont know yet urs?
I wasn't sure what to do mine either so I just did them black. I think it's a little boring now!
Im wrapping whole car in apple green so I think green is the way !!
do all 312mm's fit onto the 9n3??Eddie9n wrote:Yes these will bolt on using the original brake lines absolutely fine. The hubs are the same on the gt and gtis so the upgrade is bolt on .
It depends which 9n3 you have. If you have any other bar the gti and the pd130 you'll need new hubs which can add to costs. It also questions whether you actually require the extra stopping power and whether it will be utilised - track days etc.Tony Boi 92 wrote: do all 312mm's fit onto the 9n3??
Most 312mm's fit but make sure that they're off a car which is 5x100 - the Octavia vrs mk1, audi tt (pre 2006), seat leon cupra etc.
Hope this helps!
Hi EddieEddie9n wrote:It depends which 9n3 you have. If you have any other bar the gti and the pd130 you'll need new hubs which can add to costs. It also questions whether you actually require the extra stopping power and whether it will be utilised - track days etc.Tony Boi 92 wrote: do all 312mm's fit onto the 9n3??
Hope this helps!
i have the gti 1.8t lol, 9n3
i want a good stopping power, i need up an upgrade from these standard gtis lol
so as long as its 5x100 im good?
im considering porsche 996/boxster or just dub 312mm
what ya recon
