http://www.ebay.co.uk/sch/i.html?_trksi ... &_from=R40
and the first problem is the sections...I know what engine is and what ABS is...but what is A/T and SRS?
A/T gives linking error...so maybe I don't have A/T
SRS gives error code 532 ....low battery voltage, (understandable in this weather)
ENG gives error code 16955..brake light switch/fuse/bulb
will investigate further
John
P.S. link to fault codes
http://wiki.ross-tech.com/wiki/index.ph ... ault_Codes
