VCDS Coding
benhowarth6
VCDS Coding
Post by benhowarth6 »
Hello, hoping someone here can help me, I recently got a VCDS cable for my GTI and have been trying to code the Staging on the dials, however when I try to adapt the code it gives me the following error: Error Channel 17 Not Available. I have also tried the indicator_celebration code too but that doesn't work.
Anyone got any ideas?
I'm also looking for some other options I can enable?
Wilxay
VCDS Coding
Post by Wilxay »
Go on the adaptation menu on 'instruments' then select indicator celebration mode on the drop down list
benhowarth6
Re: VCDS Coding
Wilxay wrote:Go on the adaptation menu on 'instruments' then select indicator celebration mode on the drop down list
I've tried this but it just gives me the same error?
NMavs
Re: VCDS Coding
Post by NMavs »
Year is the car pal?
benhowarth6
Re: VCDS Coding
NMavs wrote:Year is the car pal?
Its a 2011 60 Plate GTI.
NMavs
Re: VCDS Coding
Post by NMavs »
Doesn't have staging mate that's why your getting the error
Eddie-gt
Re: VCDS Coding
Post by Eddie-gt »
It is possible to add Staging to the cluster even if "Staging and Indicator Celebration" are shown as Not available
Video clip to follow soon to prove it
NMavs
Re: VCDS Coding
Post by NMavs »
Please tell us how Eddie :-)
Eddie-gt
Re: VCDS Coding
Post by Eddie-gt »
NMavs wrote:Please tell us how Eddie :-)
You need special tools
https://www.youtube*.com/watch?v=FyfbyCMFoyA
chrispy.
VCDS Coding
Post by chrispy. »
Im confused. What special tools?
Eddie-gt
Re: VCDS Coding
Post by Eddie-gt »
chrispy. wrote:Im confused. What special tools?
A tool that can read the eeprom of the cluster, i modify it to allow staging then write it back.
chrispy.
VCDS Coding
Post by chrispy. »
Is that tool available to everyone?
