Polo 6R Stalk set Trip Computer
Forum rules
Please Use The New FOR SALE CATEGORIES when listing an item for sale!
cabbage_gti
Re: Polo 6R Stalk set Trip Computer
Thanks alot that would be much appreciated
Its a 2010 Polo TDI
Its a 2010 Polo TDI
you will need a stalk set that starts with 6Q0cabbage_gti wrote:Thanks alot that would be much appreciated
Its a 2010 Polo TDI
cabbage_gti
Really?
Mine is a Polo 6R, seems odd that it would have a 6Q part number?
Anyway assuming I can get hold of the stalk is the installation just the same? 3 wires and coding? Did you say you had the wiring diagram handy?
6Q0 relates form 2009 - mid 2012cabbage_gti wrote:Really?
6R0 is for end 2012 - onwards
You can fit the 6R0 but then you need to change the slip ring too
cabbage_gti
Eddie-gt wrote:6Q0 relates form 2009 - mid 2012cabbage_gti wrote:Really?
What kinda price is the slip ring? That sounds like it should be cheap but you never can tell. I've had a look on fleebay for the 6Q part and can only find the ones WITHOUT the trip computer but there are a few with the 6R0953521A part number. Do you by any chance have the part number of the slip ring? and then I will need the pin outs so I can wire it up
Thanks alot for you help
Slip ring
Without ESP = 6R0 959 653
With ESP = 6R0 959 654
- greypolo9n3
- Drives: white 6r 1.6 tdi rline/gti
Ed ive sent you a pm about my cruise. sorry to knob in on this thread, not sure if its been sent to you
repliedgreypolo9n3 wrote:Ed ive sent you a pm about my cruise. sorry to knob in on this thread, not sure if its been sent to you
Bump
will also include the 3x wires to make it work and instructions
I fitted a stalk set with cruise
adding the 3x wires and coding = working trip computer controlled by stalk
Roundsquare
Ed I'll take this if it will work with my daughters Polo 6R 2012 and you give me a rough idea on how to fit it before I buy it. Just to see if I will be able to do it or if its destined to end up just sitting in my toolbox for a few years!
From VCDS I have:
Address 17 gives me 6R0 920 960 G
From VCDS I have:
Roundsquare
follow the guide to take the wheel off, and take the stalk off
http://www.uk-polos.net/view ... 10&t=54171
insert 3x wires in the plug and 3x wires in the cluster plug
Roundsquare
Sorry I had totally forgot about this.
Cheers Ed, the guide seems easy enough to follow but what plug and what cluster plug?
you fit 3x wires in the plug on the steering columnRoundsquare wrote:Sorry I had totally forgot about this.
The cluster is removed and the plug which plugs into the cluster is where the wires go
