VCDS - Boost Logs
VCDS - Boost Logs
Has anybody here got experience in using VCDS for boost logs, etc? Having trouble locating the correct measuring blocks for boost and timing. Module 08 isn't available on these engines / ECUs so you can only use the advanced measuring blocks. Any help would be greatly appreciated
Cheers Nathan
Re: VCDS - Boost Logs
i did some on mine ill have a look in the morning and find out what i used !
Top man! Cheers pal, much appriciated
