Locked
Excellent Mart!n, I need your help, best by PM. (personal information)
Watcher
Post by Watcher »
here is Martin's info..
VCDS Version: Release 12.12.2 (x64)
Data version: 20140212
CarTrends.dk
Thursday,06,March,2014,14:51:53:58762
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 10 15 17 19 25 37 44 55 56 61 77 0B
VIN: WVWZZZ6RZEY016563
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 B HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0712
Revision: B9074001 Serial number: 0571 154131224
Coding: 64B0293F08A1000021280F916CEB0FD07AC0672F7E0530C1200000030000
Shop #: WSC 12345 123 12345
VCID: 2D5AB40D74F4B476001-8078
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 150513 05 54 0403
Coding: 02302D
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1621
Coding: 58BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1621
Coding: 58BC30
Subsystem 4 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0033
Coding: 820000
Watcher
Post by Watcher »
Im gonna try and install your version of the autolight tomorrow on a customers car since you cannot buy it from kufatec anymore, so hopefully it will work aswell;)
Sent from my Aiiiiiiightphone
joelburbidge
Post by joelburbidge »
Ciclo's version works better then the kufatec one
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
joelburbidge wrote:Ciclo's version works better then the kufatec one
My Kufatec kit works just fine. Only thing is that my rear foglight doesn't work anymore. But didn't ever use that anyway so made to reverselights instead. :)
Watcher wrote: :)
Perfect, do not worry, everything will work correctly. I have checked on several VW POLO 6R with different BCM.
I've updated the post. Now it is better. Read at the end in coding with VCDS.
http://www.uk-polos.net/view ... 20#p474658
Thank you again. I wish you much success with your work. :wink:
Joelburbidge thanks, I hope you enjoy your automatic lights, it's a good change (mod).
Mart!n-GTI-DK
If I ever decide to get the rear foglught working again I will have a go at it with your setup aswell. :)
Tribute to my little-big Polo 9N3 and some mods I've done recently.
Vw Polo United 9N3 1.2 60cv 44kw 5-speed.
Image Image Image Image Image
-Autolights
Module 17-pin to 10-pin for VW.
Low Beam: MTEC.
Sidelights: PIAA.
I placed the module in the relay bracket, removed the Jumper 2 and Jumper 3 from the module and I connected the red wire to the signal of the direction indicators. The light sensor glued and tied with plastic clamp to the A-pillar trim.
Thus, the automatic lights, coming and leaving home are working properly.
-Cruise Control System
Changed BCM 6Q2 to 6Q0 to work (also works with 6Q1). Transfer coding Cent Elect (also adaptation) and Gateway. I bought in eBay.de
Stalks: http://www.aliexpress.com/item/fabia-an ... 35136.html
Wiring: made by me.
Help link: http://pimpowski.de/GRA_nachruesten_pimpowski.htm
Some pictures and info:
Works like a charm.
-LED lights in the domes.
-Front footwell lights.
My vw polo 9N3 does not have lower trim and this was the solution:
Watch Live is much better, my camera is not very good.
Links:
http://www.aliexpress.com/store/product ... 76106.html
http://www.aliexpress.com/store/product ... 58051.html
-Stowage compartment with cover 6Q0857465D
Now can leave things in that space without being visible and not fly away at the first corner.
-Change of standard bulbs fog lamps to LEDs Cree 50w 800 lumens HB4
http://www.aliexpress.com/item/2pcs-lot ... 37099.html
Remove covers and fog lamps. Release connector and turn the bulb holder.
Note that in the right cover there is a phillips screw to be unscrewed before removing the cover. When the bumper repainted in the official dealer (800 € to insurance, 2 bumpers, 4 areas), they forgot to disassemble this screw and damaged the grip zone.
So many times I'd rather not talk about it and not post pictures on the forums ... The paint on the horn is impossible not to publish ...lol...
Gannu
Drives: 6R 1.6 TDI 105 PS
Re: New Member. R-line 1.2 TSI 90hp 119gr.
Post by Gannu »
ciclo wrote:Light in glove box oem.
Positive. Fused always.
Negative. Ground.
ciclo, I need some help here. How did you wire the positive terminal? I mean where did you connect it to? You have encircled the purple fuse (3A) but how did you wire it to that terminal?
I extracted the electric power from a slot which was empty but with positive sign (+30). Slot 49. Internally, in the fuse box, is a power strip supply
http://workshop-manuals.com/volkswagen/ ... ash_panel/
-Current fuse box.
- Prior to folding mirrors.
Gannu
Post by Gannu »
That looks like something only a qualified DIY guy like you, could do. Not definitely me. :(
Can it be tapped from the glovebox? Or how about the cabin light itself?
The cabin light has 3 terminals. I believe that one is for ground, one is for the door activation (close/open) signal and the other is for the 12V. I am thinking of tapping it to the 12V terminal so it remains ON permanently.
We could screw the other to the ground/body.
Pin assignment on the cabin lights. Dome.
1 - Brown/Black: ground to lights work with the opening/closing door.
2 - Red/Black: positive (+30)
3 - Brown: ground.
You can see numbered on the connector or socket.
Update vw polo 9N3, front footwell lights http://www.uk-polos.net/view ... 01#p477801
Locked
