Adjusting top mounts
dantheram
Post by dantheram »
To cut a long story short i had a crash and was left with negative camber on the front drivers side.
i placed a camber bolt on the strut and fixed it but it has reverted back to neg. i'm obviously going to try and readjust with the bolt but heard you could get some play into the leg by adjusting the top mounts - how do you do this?
thanks,
Dan
alexperkins
Site Admin
Re: Adjusting top mounts
Post by alexperkins »
The top mounts are fixed position. You'd have to get adjustable top mounts to achieve this.
dantheram
Post by dantheram »
presume they'd be on ebay?? what exactly am i searching for? top mount bolts?
jonni3
Post by jonni3 »
It would be the whole top mount assembly, adjustable top mount they look pretty trick & need setting up properly.
Would it not be cheaper to replace the strut as it sounds like yours is damaged ......
dantheram
Post by dantheram »
I don't know what's wrong - the leg looks ok but the wheel is roughly sitting at -3degrees camber. It's doing my head in, I surely couldn't have bent the chassis I only crashed at low speed.
alexperkins
Site Admin
Have you replaced the wishbone
dantheram
Post by dantheram »
Yeah,
wish bone and track rod.
going to put a new strutt on - can i use a standard 6n2 one? or are they special on the gti?
ah actually - i've just remebered that i replaced the strutt too :oops:
so i'm still at a loss to work out why my wheel is tipped over :evil:
Dan
alexperkins
Site Admin
Did you do the ball joint?
dantheram
Post by dantheram »
Nope - definitely didnt do that.
You reckon it's worth a try - the camber is about -3 at the mo (is that in the reamls of broken ball joint?)
Dan
