So i had the inevitable gearbox issue and I've lost my 5th gear.
I've been to see a gearbox place and hes got all bits to repair it apart from what he calls a 5th gear pair.
I went to VW to get the part but he didn't know which part it was. he printed out the illustration so i could find out.
http://www.imgur.com/ZR8RP8m (Click the picture to enlarge )
Does anybox know which part it is?
Thanks in advance
Help identifying 5th gear pair?
- joe2612
- Location: Guildford, Surrey, Drives: Polo GTI 6n2 Black
Re: Help identifying 5th gear pair?
Yeah that diagram isn't helpful.
What you need is this:
http://www.ebay.co.uk/itm/Seat-Cordoba- ... 19d80dce1c
They are expensive from VW however,so i would suggest searching for a used set. The standard ratio for 5th in the GTI is 0.85, but I have installed a .74 for a better cruise.
Joe
Joe
phileep
- Drives: Polo Beats 2018
Thanks alot! ill look into getting a set. Sorry what do you mean a better cruise?joe2612 wrote:Yeah that diagram isn't helpful.
Joe
Phil
- joe2612
As in lower revs, so less noise and vibration.
