RCD510
Connorlee2013
RCD510
If I bought an rcd510, would it integrate as normal with the Bluetooth bury unit like the rcd310 does or would it need coding? For example would my calls etc still come through my radio seeing as it isn't the original setup? Cheers guys
Re: RCD510
Exactly the same mate
Connorlee2013
RCD510
Perfect cheers bro
Connorlee2013
RCD510
What about the aux aswell? Then I'll have 2 ports so what will be the crack there?
Re: RCD510
Aux is the same too. They have the same interfaces
Connorlee2013
RCD510
So will both work or just the one?
Re: RCD510
How do you have two? Normally you'll have one aux and one MDI plus a potential aux on the bury kit
Connorlee2013
RCD510
Am I right in thinking the rcd510 has an aux input on it?
Re: RCD510
The same as the rcd310 has buddy. One MDI and one aux
Connorlee2013
RCD510
Ah cheers lads spot on
