- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
Re:
I have rain sensor... How else would the car know if it was raining?Raptor1 wrote:I think it works if the car is fitted with rain sensor for the wipers.
Re:
Absolutely right.Raptor1 wrote:I think it works if the car is fitted with rain sensor for the wipers.
Mart!n-GTI-DK wrote:I have rain sensor... How else would the car know if it was raining?Raptor1 wrote:I think it works if the car is fitted with rain sensor for the wipers.
As I said here:
http://www.uk-polos.net/view ... 15#p480564
Link:
http://www.aliexpress.com/item/New-Gas- ... 36317.html
Low quality video. The nicest thing is the music.
(time to pretend)
With this video, I do not intend to harm anyone, quite the opposite.
Safety is first.
Obviously I have disassembled.
To whom it may concern, improve rubber fastening of the brake and clutch pedal.
The accelerator pedal is perfect.
Solved: http://www.uk-polos.net/view ... 25#p484325
Link:
- Mart!n-GTI-DK
- Platinum Member
I'm glad I didn't buy a set and tried myself.
unnecesary info
New Mod. Auto folding mirrors OEM.
This tutorial is especially dedicated to Holger44805 (GE) and peter_dk25 (DK).
I hope it's very useful for romingo (FR) and Israel (SP), of course is available to everyone.
Before continuing I want comment that coding is not the same for Polo 6R four doors. After playing for a couple of hours with hexadecimal and binary, I got the correct coding so that everything works correctly on a Polo 6R with four doors without losing any feature.
Parts:
There are different references depending on the situation of the steering wheel (LHD, RHD) and the number of doors.
You can find the right parts here:
http://ifinterface.com/page/page3.php?langid=2
http://www.uk-polos.net/view ... 13#p466570
To my R-line four doors LHD:
http://www.carparts-pros.com/index.php
Switch:
6R1959565GREH
Mirrors:
6R1857507R9B9
6R1857508R9B9
Window regulator motors:
6R0959801BD Z0D
6R0959802BF Z03
Wire: 0.5mm2... 3.5m
http://www.ebay.com/itm/0-5-mm-Thinwall ... 7926fa2892
Contacts:
http://www.a4-freunde.com/showwiki.php? ... zu+gehoert
http://www.ebay.com/sch/dachsmax/m.html ... _PrefLoc=2
MQS
N 907 647 01... 5x
A 032 545 39 28... 4x
Trims, mirrors:
http://www.aliexpress.com/item/4PCS-Car ... 48088.html
Window regulator motor:
Electrical diagrams:
Wiring necessary
Passenger door: Two wires.
-T10v/4-------to------- T16l/15 (J387)
-T10v/2-------to------- T16l/14 (J387)
(J387) is window regulator motor.
T10v is a coupling.
Driver's door: Three wires.
-T10f/4-------to------- T16g/15 (J386)
-T10f/2-------to------- T16g/14 (J386)
-T10k/8-------to------- T16g/12 (J386)
(J386) is window regulator motor.
T10f is a coupling.
T10k is switch connector door mirrors.
Coding VCDS:
In label 6R0-959-801.CLB, descriptions of the bits are not available, is recommended to write the hexadecimal with keyboard.
Two doors
Undersystem 2 - Styreenhedsnr: SW: 6R0 959 801 BD HW: 6R0 959 801 BD Forklaringsfil: NEZ\6R0-959-801.CLB
Komponent : J386__TSG_FT 003 8620
Kodning : 0280AB
Undersystem 3 - Styreenhedsnr: SW: 6R0 959 802 BF HW: 6R0 959 802 BF Forklaringsfil: NEZ\6R0-959-802.CLB
Komponent : J387__TSG_BT 003 8620
Kodning : 1080AB
Four doors
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF
Component: J387__TSG_BT 003 8612
Coding: 1000AB
Works perfectly, like a charm and I very happy about it!
Video
Tilt passenger mirror when putting reverse
Why is not possible tilt passenger mirror in Polo 6R?
- Because the signal regulating power mirrors is through of the fuse SB12, and not from the BCM, so tilt passenger mirror is IMPOSSIBLE with original parts.
With rear view camera, solved it.
BCM provides the following functions for the wing mirrors in Polo 6R:
Heated
Directly, for example when is active heated rear window.
Folded
Through BUS line with comfort function for remote.
Parts:
Switch:
6R1959565GREH
Mirrors:
6R1857507R9B9
6R1857508R9B9
6R0959801BD Z0D
6R0959802BF Z03
Contacts:
MQS
N 907 647 01... 5x
Trims, mirrors:
Wiring necessary
T10v is a coupling.
T10f is a coupling.
Coding VCDS:
Two doors
Kodning : 0280AB
Kodning : 1080AB
Four doors
Coding: 0200A3
Coding: 1000AB
Video
Heated
Folded
Hi circlo, could you help me with this one please, my 2011 6r has central locking but not remote, is it possible to retrofit?
Cheers in advance
Dom
Cheers in advance
Dom
Hi Domjames,
What is the reference number BCM of your vw polo?
http://www.uk-polos.net/view ... 05#p473516
Ciclo, sorry to be a pain, is there any easy way to find this part number?!
Ciclo, thank you!! Mine is 6R0 937 085Low / medium
benzinkopf
- Drives: 1.2TSI 105HP DSG7
Hi Ciclo, on the Rain closing, do you have Rain closing Option on your instrument cluster MFA+? I don't have MFA+ in mine, so I'm not sure whether the rain closing box is there or not. I believe, to activate the feature, we need to enable the code in BCM, in sub-code RLS, and in the Instrument Cluster setting.
Damn, the more difficult ...Domjames wrote:Ciclo, thank you!! Mine is 6R0 937 085Low / medium
Do the following
-With VCDS check that bits 3,4,7 are marked.
-Lower the driver and passenger windows (and rear if any) in half.
-Close the door.
-Enter the key in the door lock cylinder.
-Turn the key clockwise (close LHD
If the windows go up while holding ... congratulations! Tell us the results.
I checked in my r-line and it works perfectly, up the windows and mirrors folded. (bus line T16/5 both window regulator motor to T73b/17 BCM)
