If you have DAB, where is your aerial? Is it OEM?
Where is your DAB aerial?
Re: Where is your DAB aerial?
on the roof, OEM all the way
Yeah I have a roof mounted aerial.. Buts its only FM
Reason I asked is the radio said the FM signal is coming from 2 antennas..
Both were on, the DAB antenna was off.
I thought "maybe there are 2 antennas - one in each wing mirror.. And the roof aerial is infact a DAB antenna but not connected.
Sadly I was wrong
Sadly I was wrong
