where can i get a ross tech vag com
tommytse22
- Drives: polo gti
where can i get a cheap vag com for polo gti ? nearly 300 quid is a bit costy?!
Tony Boi 92
Re: where can i get a ross tech vag com
you can get cheap reps off ebay for like a tenner, but nothing like the genuine
tommytse22
- Drives: polo gti
can i changed code and stuff though with ross tech program ?
thank you
thank you
- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
I have one of these.
http://www.dhgate.com/product/new-arriv ... |297809938
Works perfectly with the 6R.
tommytse22
- Drives: polo gti
Mart!n-GTI-DK wrote:I have one of these.
thanks for the link!
so this tool work with the polo 6r? and work with ross techs software?
i want it to changed codes and teaks the car? or should i buy the real deal for that ?
thank you
If that rip off Chinese copy works as well as VCDS from Rosstech, then I'd expect Rosstech to be seriously worried!
Personally I'd expect that not to work fully like the legit versions of VCDS do, but what do I know?
As far as I know, VCDS Vers 12.*** will only work with genuine cables.
tommytse22
- Drives: polo gti
so there is no way to get one of these and changed and teak settings? unless i buy from Rosstech ?RUM4MO wrote:If that rip off Chinese copy works as well as VCDS from Rosstech, then I'd expect Rosstech to be seriously worried!
thats a bummer! i wonder if anyone is around essex with one that can let me use since im only going use it once and set settings and probs never will use again
