6R - Multifunction Steering Wheel Retrofit
- jammydodger
- Drives: 6R GTI
Re: 6R - Multifunction Steering Wheel Retrofit
Sorry for dragging up such an,old thread but can anyone tell me if my airbag from a plastic non-multifunction steering wheel will fit into a leather non-multifunction steering wheel... Thanks
It will not sadly
The leather steering wheel is a different design regardless of being multifunction or not (same wheel, just has blanks)
- jammydodger
- Drives: 6R GTI
As far as I know, the airbag DOES fit (50/50 chance) if going from a leather round non-multifunction steering wheel (Polo Advance) to a round multifunction steering wheel (Polo Sport) with ONLY left buttons. It won't fit if updating to a MFSW with left and right butons.
I am really confused here,
Does the airbag, from a leather highline steering wheel, fit to a NO-multifunctional T5 (Gt/etc) wheel ?!
What should we guys look for in order to be certain ?!
Has anyone tried the above combination that i mention ?
Airbag from leather steering wheel to a T5 nomulti steering wheel .
Timbo220181
Guys, sorry to drag up an onld thread - I'm about to take stock of an R line Polo and the MFSW isnt an option annoyingly.....
Having spoken to parts they are about as clear as mud. Please can someone confirm which bits I need to do this retro fit?
Is it just the buttons and the cruise stalk? Obviously I have the R line flat bottomed wheel so I wont need the air-bag correct?
I seem to be getting told it cant be done in the dealerhsip, but this DIY says otherwise
Many thanks
Many thanks
The LIN-BUS can also be found on T28a/16 (connector to the driver door LHD cars). Perhaps it's easier for some
AntonDelin
- Drives: Polo 1.2TSI DSG GT
Thank you very much Der Finne for a great DIY!
How about us who already have a standard left spoke mfsw, do we only need the coding when retrofitting a GTI steering wheel?
Thanks in advance
Thanks in advance
I have 2015 1.2 gt tsi with flat bottom steering, with buttons on both sides, from India. Which steering with paddle shifters can i fit to my car?? Can anybody provide part number?? Thanks
not even coding (sorry for the late answer, but maybe someone else will profit)AntonDelin wrote:Thank you very much Der Finne for a great DIY!
Thanks in advance
AndreasSPunkt
- Drives: Polo 6R GTI
Hello,
sorry for my bad english.
Can someone tell me the partnumber of this clip with gti logi in black?
Will this work on Polo 6C?
Built date is 10.05.2015
It has no buttons on steering wheel at all and in car shop they said to me that I need to change AirBag Centrale, Steering wheel centrale and the price for all that is around 3000€
neil.cowie
Great how to. Going to try with my t5 caravelle. Can I to the programming myself or do I need to use a garage.
Neil
Neil
Easy to do yourself with vcdsneil.cowie wrote:Great how to. Going to try with my t5 caravelle. Can I to the programming myself or do I need to use a garage.
Neil
no you need a different procedure for polo 6c. it depends whether your bcm will support it. the airbag ECU and steering angle sensor do not need to be replaced.vnanic wrote:Will this work on Polo 6C?
Hey guys,
I just fitted a highline steering wheel with MFSW but I have a problem. After I wired everything and coded, my BC buttons don't work. They still work from the wiper lever, but not from the steering wheel. I tried every coding I could find but still nothing. I even changed the wiper lever with one without BC buttons, but still nothing.
I'm out of ideas..what should I change so I could make it work ? Could it be the slip ring (my polo is the first generation, 2009-2010) or the airbag wiring ? my airbag wiring has a "D" at the end instead of "A" and the slip ring has an "E" at the end. The steering wheel is made by TRW in 2016, the same with the wiring.
The music buttons work perfectly..
