Thats right. They are connected to the side lightsciclo wrote:You should consider that your LED module is powered by the wiring of the side lights.crosspolo2014 wrote: i think somewhere in VCDS is a adjusting of the voltage for the led's. but where??
seems clear that the failure of the LEDs is related to voltage fluctuation. Checks if after driving more than 20 minutes, the LEDs have the same problem.
I think so, but is there in vcds any setting for the side lights voltage?
