- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
I totally missed that the last time I tried to see if it was possible.ciclo wrote:You can adjust it in the settings menu of RNS510, the options are day/night/automatic, select automatic.Mart!n-GTI-DK wrote:How did you get it to do that automaticly???
Forgot to tell you that it is in the display settings.
Do you remember this?
http://www.uk-polos.net/view ... 30#p480972
It is solved in a simple way, the result is "excellent". I will put pictures when installing the footrest Golf GTI/Audi S1.
Explanation:
6R pedal caps:
http://www.aliexpress.com/item/Stainles ... 53100.html
Mixing between 6R and 6C pedal caps: The ones I bought shown in the video. "Solved"
http://www.aliexpress.com/item/New-Type ... 62141.html
6C pedal caps:
http://www.uk-polos.net/view ... 55#p484132
http://www.aliexpress.com/item/Stainles ... 91178.html
Pedal caps between 6R and 6C are not supported.
Excellent results!!! Fixing is better than the original 6R. http://www.uk-polos.net/view ... 72#p485572
Threading the plastic clamps as shown in the following image.
The caps have holes but not in the end side of the pedals. You have to make holes with a punch (prick only) at the ends of the gum. Go through these holes and the holes themselves pedal, so that plastic clamp is between the rubber and metal.
It is very easy.
Explanation:
6R pedal caps:
6C pedal caps:
It is very easy.
- Mart!n-GTI-DK
- Platinum Member
So you make 4 holes in the clutch and brake pedalcovers and feed a cabletie through it and essentially tie the covers to the pedals?
Moved to previous message.
benzinkopf
- Drives: 1.2TSI 105HP DSG7
Ciclo,
do you know where we can get the connector for most of the Control unit and Sensor to retrofit the system in VW?
for example, we can easily get the Interior Monitoring Sensor near to the roof top, but where to find the connectors?
benzinkopf
You re the VW bible. thanks man!
98octaneblood
- Drives: Blue GT MY15
Ciclo, I need your help. Can you please find the references for the exhaust tips of the Golf GTE, Ican't from my database. I guess that the exhaust end diameter should be the same as my Polo, they share the 1.4 TSI engine.
Your engine is CZEA
Your rear silencer is the same as the BlueGT 6R. engine CPTA
Then you can install the same as the 6R GTI or Audi A1.
6R
https://www.google.es/search?q=6R025382 ... =6R0253825
A1
Those who already I mentioned earlier. http://www.uk-polos.net/view ... 70#p484270
The rear silencer of Golf GTE is not the same as yours. Chrome trims are united from the factory.
6R
A1
98octaneblood
So, my contact at the dealer is wrong since he tells me that 6R set is not valid for 6C. Maybe he's wrong, I've caught them before mistaking or ignoring things I ask.
Thanks!
Thanks!
- Mart!n-GTI-DK
- Platinum Member
It is the same exhaust as a 6R. So the the same exhaust trim will fit yours. The part number is: 6R0 253 825 and you need two of the.98octaneblood wrote:So, my contact at the dealer is wrong since he tells me that 6R set is not valid for 6C. Maybe he's wrong, I've caught them before mistaking or ignoring things I ask.
Thanks!
98octaneblood
Thanks Martin, I hope that the ordered pair of black gloss tips from Audi will fit...If not, I'll go for those you mentioned.Mart!n-GTI-DK wrote:It is the same exhaust as a 6R. So the the same exhaust trim will fit yours. The part number is: 6R0 253 825 and you need two of the.98octaneblood wrote:So, my contact at the dealer is wrong since he tells me that 6R set is not valid for 6C. Maybe he's wrong, I've caught them before mistaking or ignoring things I ask.
Thanks!
