I'd like to see that too. Some people think tuning boxes are 'spikey', and maps aren't, but as ever it depends on who programmed the box and who did the map. A tuning box contains a map, so it's the same thing, just not in the cars ECU. The big German tuning houses are all producing some very serious piggy back boxes now, as VAG have locked down their ECU's so well that they are very difficult to decrypt.Jamesbluegt wrote:I'd pay to see "documented evidence" that a tuning box has caused bent rods
One thing I should have mentioned in my post above is I have no idea how much power the standard 1.6tdi rods will take, and I suspect nobody else does. It's too early to say whether any of these 180-200bhp modded cars are reliable I'd say.
Amig, it sounds like you knew much more than you first let on with regards to which way you want to go!
Good luck with it, and don't forget to update us as you go along, it will be interesting to see once finished.
