My little 6r Tsi from Spain
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Re: My little 6r Tsi from Spain
Post by Mart!n-GTI-DK »
Can I get the Part number for the 6C GTI grill?¨
And WOW that steering wheels actually looks cooler without the buttons... Looks more like a Porsche GT steering wheel. :P
And can you see it the 6C GTI grill has the same kind of "flat spot" behind the GTI badge as the 6R GTI grill?
Nicomati
Drives: VW POLO 6R
Post by Nicomati »
Hi Mayhem,
I have small contacts in VW Navarra hehe... this steering wheel is very beautiful and it's very comfortable!!
It gives you a great change to the car!
Greetings.
Nicomati
Drives: VW POLO 6R
Post by Nicomati »
Mart!n-GTI-DK wrote:Can I get the Part number for the 6C GTI grill?¨
Hi Mart!n,
thanks for the comment!!!
sorry i bought the Gti grill in Ebay and i havent the part number of the item...
yes, the grill 6C GTI has the same ''flat spot'' s**t...I bought a tsi emblem to cover this part of the grill.
I will upload photos when you have received this!
Greetings.
Mart!n-GTI-DK
Nicomati wrote:Hi Mart!n,
yes, the grill 6C GTI has the same ''flat spot'' ****...I bought a tsi emblem to cover this part of the grill.
Greetings.
The part number is stamped on the back... Just want to confirm that it is: 6C0 853 651 E WYR
Nicomati
Drives: VW POLO 6R
Post by Nicomati »
Greetings.
Oh, didn't know where it was item number. When take the car will look the reference!
IZVVC
Post by IZVVC »
Great looking car! :D
is the steering wheel a straight swap?
Mart!n-GTI-DK
IZVVC wrote:Great looking car! :D
If you don't have buttons, Then yes.
Mart!n-GTI-DK
Did you get a chance to confirm the part number with the one on your GTI grill?
Nicomati
Drives: VW POLO 6R
Post by Nicomati »
Mart!n-GTI-DK wrote:Did you get a chance to confirm the part number with the one on your GTI grill?
Sorry for the delay Mart!n.. I was so busy with examns, work, etc....
I attached the bill. You can see the reference of the piece!
Greetings.
Mart!n-GTI-DK
Thanks. :) Just needed to be completly sure before I ordered one both ciclo and I had found the same number. But I just needed the finale bit of proof. :P
Nicomati
Drives: VW POLO 6R
Post by Nicomati »
Hi at All!
Sorry for being absent! Between the work and the university i've been very busy.
In this time i've done a little modifications in my polo! The first and the most important is the OEM bixenon headlights that with ciclo's help may that all the lamps work as the OEM lamp. The other modification it's coming soon and are the sideskirts of vw polo 9n3 bluemotion!! very rare here in spain! i attached a few pictures! enjoy with this!! regards!
Nicomati
Drives: VW POLO 6R
Post by Nicomati »
Here the pics!!!
Greetings!
wow looks good, those OEM xenons and the 6C grill!!
Nicomati
Drives: VW POLO 6R
Post by Nicomati »
Recently arrived from Germany!!!
Regards!!!
if you're going full OEM, this is what you'll need too:
Adapter
1J0973737 14 pin
1J0973835 10 pin
headlight washers
6R0 955 453 G enlarged reservoir
6R0 955 681 second pump
1J0 973 722 A terminal connector to pump
7M0 919 376 sensor for water level
7M0 919 382 O-ring sensor
7M0 973 202 connector sensor
6R0 955 970 B hoses to washers
6R0 955 978 A washer left
6R0 955 103 A washer right
automatic leveling
6R0 941 273 B sensor axle
6R0 907 357 module leveling
6R0 612 405 holder on rear axle
Dashboard
6Q0 941 334 adjustment of interior lighting (without manual headlight leveling)
wiring looms
* BCM to headlight
* wirings to pump and water level sensor
* wiring loom automatic leveling
