Thanks, I bought them on Ebay. They came from the UK.IZVVC wrote:Car looks absolutely amazing mate, where did you get the alloy wheels from?
BlackPoloBM
blackpolobm
- Drives: Polo Bluemotion
Re: BlackPoloBM
Re: BlackPoloBM
Thanks mate, do you have a link or something or seller name?blackpolobm wrote:Thanks, I bought them on Ebay. They came from the UK.IZVVC wrote:Car looks absolutely amazing mate, where did you get the alloy wheels from?
that would be great!
thanks
blackpolobm
Re: BlackPoloBM
http://www.madmotors.co.uk/alloy-wheels.html
This is their website. I searched for my wheels but could not find them.
Maybe you can find it or contact them about it.
Re: BlackPoloBM
Watch your inbox.
Re: BlackPoloBM
Did you solve the LED's problem?
Re: BlackPoloBM
Just mention that you may not have these problems because your BCM is Maxx. Not sure because no one commented about it.boomshack wrote:Did you solve the LED's problem?
In addition blackpolobm did not make the wiring as iichel (still flashing of the leds without capacitors, everything else works perfectly).
There are many factors to consider on each Polo.
Results after install OEM xenon on your Polo are very important due to type of BCM.
blackpolobm
Re: BlackPoloBM
No, I still have the flashing LED's.boomshack wrote:Did you solve the LED's problem?
I had a adapter that was made just like Ichell's, but it did not work on my car and the canbus shuts all the led off so now I just use the flasing one untill the problem is solved someday somehow.
Re: BlackPoloBM
when you turn on Xenon the Leds keeps flashing? or do they only flash a couple of seconds until they are dimmed down?
Because if they flash while "normal" light / Xenon is on its kinda pointless, that will only get my pulled over:P
blackpolobm
Re: BlackPoloBM
Its flashing when you turn the wheel. And sometimes it flashes just a little bit. 1 time per minute or something.
Re: BlackPoloBM
This is beautiful!
Are the GTI/RLine bumpers straight-swap? And will my lights still work with them?!
Re: BlackPoloBM
yep they are a straight swap
