- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
The part 4H0937527 was actually the one that fit, but I ordered 4H0937527 through 4H0937529, so that wasn't a problem. So now everything is fine and I'm happy.
Cheers,
René
Cheers,
René
Ok, the only difference is the relay type you used later.
In any case, I'm glad you enjoy your automatic lights in the manner most OEM possible.
It's a bit dirty now, but anyway:
Thank you!
Thank you!
As I mentioned HERE
... and once received the LEDs for DRLs & turnlight (all in one), these are some of the first modifications to my project.
Changing type of connector for compatibility with headlamps of Polo 9N3
Connectors T2 (must be waterproof).
I bought this type and this amount for this and other projects.
The next step is to check that the LEDs fit on the headlights (9N3)
I have to confess I bought LEDs crazily (without measures)
, so it will be a mystery until I check if they fit in the right way...
perhaps I have to do more changes ...
edit
Tested: The LEDs all in one adjust perfectly. So lucky ...
Headlights of my 9N3 are the brand VALEO (no HELLA)
The next step is electrical installation on the car, but it will take time because I'm extremely busy with other things.
http://www.uk-polos.net/view ... 87#p494387
, so it will be a mystery until I check if they fit in the right way...perhaps I have to do more changes ...
edit
crosspolo2014
- Mart!n-GTI-DK
- Platinum Member
it is modified xenon headlight because the xenon lightpatern isn't wide enough for driving in the pitch black at a 100mph around tight curves.
jobbercete
- Drives: Polo 6R 1.2 TSI 90cv Sport
Yep, It's not photoshop.....I've been looking on the internet for quite a long time but found nothing
and those headlights will look AWSOME on my car
- Mart!n-GTI-DK
- Platinum Member
They are not available to buy... You wil have to be creative yourself with a pair of bi-xenoon headlights and a halogen dish that will fit.jobbercete wrote:Yep, It's not photoshop.....I've been looking on the internet for quite a long time but found be creative yourseelf. nothingand those headlights will look AWSOME on my car
Good luck.
Thanks guys for the clarifications.
WRC team are very skilled, I guess they did similar to this but the other way around.
Hey ciclo
your 9n3 DRL mod gave me an idea!
nowadays the multi color leds are available in many colors
i've ordered a set of red and white dual color leds.
this way it will be possilbe to have a dual-function rear fog on the left side (for uk dirvers on the right)
fog on = red emitting light
reverse on = white emitting light
combined with a white LED on the other side, dual white reverse light is possible
