Locked
It is a good idea, will be a good one mod I will do in the future (I'll copy from you ... :lol:)
The only problem is to fit this LED bulbs with two functions in the socket.
Link to buy?
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
ciclo wrote:Thanks guys for the clarifications. :wink:
WRC team are very skilled, I guess they did similar to this but the other way around.
OMG :shock:
That is the worst taking apart your headlight DIY I have ever seen. :o :shock:
If the glass is still that hard to get off after you heated it... YOU HAVEN'T HEATED IT ENOUGH!!!
Andrea 6r
Drives: 6r
Post by Andrea 6r »
ciclo wrote:
Electrical diagrams:
Image Image Image
[/b]Passenger door: Two wires.
-T10v/4-------to------- T16l/15 (J387)
-T10v/2-------to------- T16l/14 (J387)
(J387) is window regulator motor.
T10v is a coupling.
Driver's door: Three wires.
-T10f/4-------to------- T16g/15 (J386)
-T10f/2-------to------- T16g/14 (J386)
-T10k/8-------to------- T16g/12 (J386)
(J386) is window regulator motor.
T10f is a coupling.
T10k is switch connector door mirrors.
Hi ciclo;
could you explain better connections? I do not understand what are the various codes example J387 indicates what?
Mart!n-GTI-DK wrote: YOU HAVEN'T HEATED IT ENOUGH!!!
Image :lol:
Totally agree ... but it seems that is the only way to take apart the glass.
Andrea 6r wrote:
ciclo wrote: Hi ciclo;
It's an easy deduction if you look at the pictures.
J386, J387 are the motors of the windows (dark blue in the pictures above) :wink:
GUIDE Folding mirrors
Andrea 6r
Drives: 6r
Post by Andrea 6r »
Thanks ;)
you're welcome Image
Andrea 6r
Drives: 6r
Post by Andrea 6r »
I have another question .. you know where to find the "window line"?
I only have this detail "t 28/20"
I bought a kit and they told me that I need to connect a wire them but I do not understand where he is
According to the manual:
T28a/20 driver's door
T28/20 passenger door
This is the electrical signal of Central locking, in both doors.
You can locate this wire into the connector (T28, numbered) next to hinges of the doors.
You have many images of these connectors here :arrow: click and scroll down
Andrea 6r
Drives: 6r
Post by Andrea 6r »
I Have only wire on the left.I put in the pin 20?or in the 28?
alexperkins
Site Admin
Post by alexperkins »
T28 is the connector in the passenger door
20 will be the pin number to use
I guess you'll have to hook the wire that says the seller to the wire located in slot 20.
What for is the kit?
Andrea 6r
Drives: 6r
Post by Andrea 6r »
ok thanks
do you now where is the left-and right indicator in t28?
left T28a/3
right T28/3
Locked
