ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
- Andrea 6r
- Drives: 6r
thanks for everything
but this caliper where can I find?
It's called a terminal tool / terminal remover / terminal block tool. You can find them on eBay etcetera.
Ciclo, I know this was one of your very early mods, but I want to also do the illuminated glove box to the wife's car. I've looked at your instructions and parts required, and from the parts point of view all seems OK, but I just can't get my head around the two dimensions you listed for the cardboard template, and where I would need to cut to mount the light.
If you get the time, any chance of a little more explanation please (of course it could just be me being thick) ?
You can buy here:Andrea 6r wrote:thanks for everything
http://www.ebay.co.uk/sch/i.html?_from= ... tpos&gbr=1
It is good quality, I use it very often.
But if you prefer, you have this ***EXCELLENT*** guide to make it yourself.
Norbreck21a wrote:Ciclo, I know this was one of your very early mods, but I want to also do the illuminated glove box to the wife's car. I've looked at your instructions and parts required, and from the parts point of view all seems OK, but I just can't get my head around the two dimensions you listed for the cardboard template, and where I would need to cut to mount the light.
I made measurements with plastic tools, so precision is not perfect. Therefore you must overlay the lamp and check its operation before cutting.
Always the cut less than the dimension obtained to correct as necessary.
Previously, to reach these measures, I made several mathematical calculations with the lateral dimensions of the glovebox (many dimensions) to get the most beautiful situation of the lamp that was possible. Thanks to the phi number.
Maybe these calculations it's an overzealous , but I remember this beautiful work every time I open the glove box.
Light Glove Box
Hello ciclo, could you tell me how I can remove this elements:
- Andrea 6r
- Drives: 6r
Perfect thanksciclo wrote:You can buy here:Andrea 6r wrote:thanks for everything
Inviato dal mio iPhone utilizzando Tapatalk
http://www.uk-polos.net/view ... 13#p466570CNK wrote:Hello ciclo, could you tell me how I can remove this elements ?
http://workshop-manuals.com/volkswagen/
http://workshop-manuals.com/volkswagen/ ... ier_cover/
Thanks @ciclo! I am very grateful for your help
Thanks for the reply on the Glovebox light installation Ciclo, think I understand it better now.
Just a couple more questions if I may before I proceed. Firstly the dimensions you gave in the build thread (43.5mm x 24.5mm), do I assume that that is the overall dimensions of the hole that needs to be cut for the lights ?
Lastly, the repair wires (000 979 021), how many do you need to reach to the fuse box (how long are they each) please ?
Thanks.
Thanks.
You only need 2 wires to connect it to the light (+ and -). Then you can use another wire to extend it to GND and fuse box. In the fuse box, you'll need a standard power timer or a repair wire 000 979 135.
It's better not to use a lot of repair wires to reach the fuse box, since they are quite expensive and every link decreases strength and flexibility. Better to solder a normal wire inbetween.
something like:
+12V light <---- 000 979 021 ---||--- normal wire ---||--- 000 979 135 --> fuse box
GND light <--- 000 979 021 ---||--- normal wire ---> GND
something like:
Norbreck21a,
With respect to the hole: For your safety you should measure the dimensions of the lamp between the grip tabs. It is very easy because the end result is a rectangle. Cut half a millimeter less (two measures) and then you must go correcting as necessary.
Take it easy and do it skillfully because no turning back.
Regarding the wires: I use HQ automotive wires from coils 100m, and after running the wires (from point to point), I do the crimping of terminals, so I can not say exactly the length of the wires. I'm sorry.
An image of the material I use:
New Mod
Lower grill and fog covers RLine 6C. OEM.
Parts:
Lower grill R-line 6C
6C0853677J 041
Fog covers R-line 6C
6C0853665F 041
6C0853666F 041
PR-041 gloss black from factory
CHE SPETTACOLO!
Upper grill R-line 6C
Parts:
6C0853677J 041
6C0853665F 041
6C0853666F 041
CHE SPETTACOLO!
Man your polo is so cool!
This last mod is very recommended to owners R-line 6R or bumper R-line.
Thank you very much Alex, also to Mart!n, iichel, and many others... thanks for your help and good advices.
