Saty's Polo 1.6 tdi SEL - 6C GTI bumper + 312mm Brakes
Re: Saty's Polo 1.6 tdi SEL - double din installed
This audio system looks very good, I follow with attention... and patience
yahoodlums
- Drives: 2014 Polo TSI
Looks great! I have a pearl black 6c TSI. Love the wheels.
Any update on the stereo/speakers install?
Re: Saty's Polo 1.6 tdi SEL - Audio upgrades installed
Finally got around to fitting themciclo wrote:This audio system looks very good, I follow with attention... and patience.
Thanks, yep installed it over the past couple of daysyahoodlums wrote:Looks great! I have a pearl black 6c TSI. Love the wheels.
So first off i had to drill out the rivetted stock speakers. I ran 16 awg wire from the amp in the boot to the doors and crimped on some push fit connectors for the component woofer.
Picture of the crimped connections to the crossover. No pictures of the tweeters installed.
Component speakers installed and doors insulated with silentcoat. Fantastic stuff for the price
Boot hatch insulated
Pair of amps under the false floor in the boot. The alpine amp runs my JL subwoofer and the JBL amp runs the components. The alpine amp was installed last summer.
So after 2 days of work and a sh*t load of cuts on my hands was it worth it? In a nutshell, yes
Re: Saty's Polo 1.6 tdi SEL - audio upgrades installed
Great job Saty!
one question when installing your double din radio, did you need to install a new radio cage, or you just slide the head unit in, and popper the fascia around it?
Thanks !
Thanks !
Good job ... enjoy
Wear gloves next time to avoid war wounds ...
I needed a new fascia, a cage comes with the double din unit to secure the headunit. The cage slides into the fascia and u push the metal prongs down to secure the cage. The headunit then slides in to the cageIZVVC wrote:Great job Saty!
Thanks !
Thanks, I think id rather cut my hands than wear those glovesciclo wrote:Good job ... enjoy
saty wrote: Thanks, I think id rather cut my hands than wear those gloves![]()
and these?...
you know it's a joke... what matters is safety and security at work. Re: Saty's Polo 1.6 tdi SEL - Remapped 145 bhp 320nm
Had the car remapped at VRT tuning, a dealer for more-bhp
Went from 90bhp to 145bhp and 230nm and 320nm
The remap highlighted on the drive home that the braking system really needs to be upgraded, better pads and brake fluid refresh is next on the list
VRT and more-bhp done a great job and the car pulls all the way to the red line
TheFrog
- Drives: 2015 Blue GT
You're a braver man than I, sirsaty wrote:Went from 90bhp to 145bhp and 230nm and 320nm
55bhp increase, that's brave. On standard internals? That's got to be pushing almost past it limits surely?
Not necessarily; the 90bhp is just a detuned version of the 1.6TDI 105bhp. So in a sense, for that engine it is a 40bhp increase, which is about right for a diesel.Mayhem wrote:55bhp increase, that's brave. On standard internals? That's got to be pushing almost past it limits surely?
It is quite a difference compared to stock, from what I was used to its silly fast. How do the numbers compare to ur bluegt with ur box?TheFrog wrote:You're a braver man than I, sirsaty wrote:Went from 90bhp to 145bhp and 230nm and 320nm
As Lee said the CAYx engines are identical whether it's the 75, 90 or 105ps version. The 1.6 tdi engine is in a lot of vag group cars. 140-150bhp seems to be the norm Remap for the 1.6 tdiMayhem wrote:55bhp increase, that's brave. On standard internals? That's got to be pushing almost past it limits surely?
I think there's another member wih a remapped 1.6 tdi on the forum running a similar amount of power.
The Remap is a tried and tested map from more-bhp and they've used it on a number of 1.6 tdis without problems
A dyno of a 1.6tdi a3 remapped by more-bhp:
TheFrog
The DTUK box takes power from 150 to about 180, so a 20% increase.saty wrote:How do the numbers compare to ur bluegt with ur box?
Jep running 145hp with only bigger airbox/intake duct. Was a cr105 but it is the same engine. Stock internals can take 200+hp but without some serious hardware 145 is the max you can get out of it.
Yeah mines been running fine for almost a year, tempted to do the CR177 turbo and supporting mods possibly in 2017.Amig wrote:Jep running 145hp with only bigger airbox/intake duct. Was a cr105 but it is the same engine. Stock internals can take 200+hp but without some serious hardware 145 is the max you can get out of it.
Haven't updated in a while, I've fitted 312mm Discs and ATE Calipers, and also just fitted a 6C GTI rear bumper. I'll post a photo once the rear end is complete
