Paint stripped during number plate swap
beatty599
Post by beatty599 »
I have a specialist rubber piece for number plate sticker removal and it works fine on all cars, i know this as my friend is a mechanic uses it but it decided to strip bits off paint from my bumpers more than just in the image.
What do you think I should do?
Should I try and contact VW see if their warranty might cover it? or just take it as a loss and fill it in with bit of primer and cover it up with the number plate?
alexperkins
Site Admin
Re: Paint stripped during number plate swap
Post by alexperkins »
I've seen this happen many many times
Prime it and give it a coat of colour to match. VW won't be interested. They'll say the adhesive tape used was too strong
at least it won't rust since it's on plastic :)
beatty599
Post by beatty599 »
iichel wrote:at least it won't rust since it's on plastic :)
Haha that's one upside i suppose
alexperkins wrote:I've seen this happen many many times.
Thanks for the advise, it must be a thin coat on the bumpers for it to be stripped off so easily.
