Locked
Hi efre, you have a PM. :wink:
Te dejo un mensaje privado, mira tu bandeja de entrada.
Hace tiempo que no hago los cableados de luces automáticas para su funcionamiento OEM. No obstante hay una empresa alemana que los vende https://www.x2car.de/Coming-Leaving-Hom ... egensensor y que una vez instalados funcionan igual de bien.
Te proporcionaré toda la ayuda que necesites (instalación, vcds, etc...).
New mod
- MFSW Polo 6C R-line 1K8419091 AP
- Airbag 5G0 880 201 J ..or.. 5G0 880 201 AC HVF/03S
- Airbag wiring 7E0 971 584 C
It works perfectly except the button illumination, is necessary to change BCM to solve it (BCM 2015-->), I will do it coming soon ... :)
VCDS
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Coding: A4FFFF
Image thanks. and you?...
Same story. Buttons work and are very comfortable, but no background illumination.
Spolos
Drives: Volkswagen Polo 6R Comfortline 2012
Post by Spolos »
Guys,
I swaped my BCM from 6R0937087K to 7H0937089F in my Polo 6R from 2012 everything seems te be in order save for 2 things.
First off my instrument cluster display indicates that rear reverselight dos not work but it works just fine so the instrument cluster display is wrong in VCDS i have tried to erase the error massage evendough the error is removed in VCDS the warning light still apears in my instrument cluster display.
The other mailfunction is my corneringlights do not seem to work while the workt fine in my previous BCM on VCDS indicates that the work currectly but the don't when i put on the foglights they funtion properly
You guys have any tips or any idea's how to solve this
Much apriciated,
SpoloS
I guess it could be that the T5 Transporter has a double reverse light, while the 6R only has one. So it is missing the second one.
About the fog lights/cornering lights, I'm not sure. Normally you can code to operate the fog lights trough fog lights (or actually, fog lights trough cornering lights).
Fog lights in cornering lights: 1 wire per light unit, from BCM to light unit (i believe T73b/9 and /10 resp left and right)
Fog lights seperate from cornering lights: 1 wire per cornering light to xenon headlight (resp T73b/9 to left T14/14 and T73b/10 to right T14/14) and 1 wire from headlight switch (through fuse box) to both foglights.
But I do not understand why it is not working now. Can you check the fog light coding and cornering lights coding?
Spolos wrote:... so the instrument cluster display is wrong
:lol:
Both failures have easy solution.
Probably:
reversing light --- wiring reversing light is not attached correctly on BCM
cornering lights --- codification fault
VCDS autoscan :?:
Andrea 6r
Drives: 6r
Post by Andrea 6r »
hello ciclo, you know the code of the terminal "small" of the fuse box (the ones in the red circle)?
do you mean these?
Andrea 6r
Drives: 6r
Post by Andrea 6r »
the picture is not seen :(
I think you mean a junior power timer connector.
See here:
https://www.google.nl/search?q=junior+p ... 2&bih=1281
:lol:
Probably:
VCDS autoscan :?:
no, you were not reading...
Spolos wrote:the instrument cluster display is wrong
:lol: :lol:
The problem is that the Polo 6R has several ways to connect and provide power to the reversing light, it is depending on equipment ... halogen headlight, factory xenon, blueMotion, manual transmission, etc ...
BCM089F software detects a fault in the wiring and reflected in the instrument cluster.
Andrea 6r wrote:hello ciclo, you know the code of the terminal "small" of the fuse box
http://www.uk-polos.net/view ... 10#p477916
http://www.a4-freunde.com/showwiki.php? ... zu+gehoert
Andrea 6r
Drives: 6r
Post by Andrea 6r »
thanks ciclo, but I do not understand, if is: N 103 357 06 ( 1.5 ) or N 906 844 05 ( 2.8 )
Junior Power Timer 2.8
N 906 844 05
You must choose according to thickness of wiring.
Locked
