Hello,
I try to do additional trunk lights (like ciclo), but I don't know, where I should connect wires from lights?
Ciclo's intstruction: https://drive.google.com/file/d/0B2nv91 ... FTMFk/view
Where I should connect the beam to the red-black cable?
Do I need to connect one cable to the T5h on the left and the other to connector on the right side of the trunk?
I found these some pictures:
http://forums.tdiclub.com/showthread.php?t=358501
http://forums.vwvortex.com/showthread.p ... ts-our-car
Is there a better way to connect wires?
Regards
Second/central trunk light - where to connect the wires?
- CNK
- Drives: 6R
- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
Re: Second/central trunk light - where to connect the wires?
The easiest way wuld be to just solder the wires to the wires going to the original trunklight...
- Andrea 6r
- Drives: 6r
Hello
I connected a wire to the red and blue and I added mass to the "hub" that is also seen in pictures ...
But the light bulb does not work and I remain on the interior lights
where did I go wrong?
the 'mass' wire is T5h/1
the other wire is a PLUS
- Andrea 6r
- Drives: 6r
https://www.youtube.com/watch?v=4iXzCKi9e3E
So what do I connect?
current,the + 30, from where I take?
most ideal would be a terminal 30 +12V. always fused.
if i remember correctly, you have a fuse box for your folding mirros. you can maybe take a wire from that fuse installation and guide it to the rear.
so the positive (terminal 30) goes to one wire, the other wire to T5h/1
then it will work
then it will work
- Andrea 6r
- Drives: 6r
in the end I got it from red / black that is there in the area
It should be the ceiling, so "perfect"
- Ugabista
- Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Hi Andrea 6R, then where you connect exactly 2 wires the new lamp?Andrea 6r wrote:in the end I got it from red / black that is there in the area
Tell me in words rights, not pictures [emoji3]
- Andrea 6r
- Drives: 6r
hello, mass, I connected to the red wire and blue
the current, I got it, the red and black wire that goes up into the sky
If you want the second trunk light works like the original light and it is protected by the same fuse:
+ hook the positive wire (2) to pin number 2 of the original light
- hook the ground wire (1) to the red-blue cable (shown in the above picture)
Or if you prefer hook the two wires to the two wires original trunk light. As it has been said earlier.
Come on! it is easy.
- Ugabista
Okay, simple, just give work
I was playing as Andrea 6R
One day I make this mod.Andrea 6r wrote:Hello
