Hello
I have 06 Polo 9N3 GTI with standard steering wheel no multifunction buttons
If I add an MK5 Golf GTI flat steering wheel like this one
How do you add the Multifunction module to make the buttons work?
Would a steering module like this work?
Do I need to modify any wiring if I use my Polo airbag? or does it plug & play
Retrofit Multifunction MK5 GTI wheel WITH Multifunction?
- blazeguarder
Re: Retrofit Multifunction MK5 GTI wheel WITH Multifunction?
You can reuse the airbag as it's the same but the multifunction wheel is a no-go I'm afraid - there isn't the facility for it in the head unit
What about with an aftermarket head unit?
What would I need to make it work?(i have a pioneer dvd nav)
Would a A steering wheel control module plus some vcds coding do it?
Bump! Interested in this myself as I too have an aftermarket h.u. (pioneer DVD/BT etc)
