Hi Guys
My son has just brought a MK2 2 door 1.0 Polo as his first car. He got the car cheap because had the head gasket had gone but that has now been fixed.
Our problem is when he took it to have the MOT it failed miserably on the emissions test, the results are
Fast Idle test
CO = 12.39% (max = .3)
HC = 670 (max = 200)
Second fast idle test
CO = 12.55
HC = 922
These are really high.
so far our mechanic has replaced the lambda sensor, checked the temperature sensor. we have sent the ECU away to ECU DR and it was returned as having found no faults and working as it should. On Monday we are changing the cat, although our mechanic doesn't seem to think this will cure the problem
Although the car smells a bit rich it actually goes really well. If there is anyone out there that has had similar problems and knows a possible solution we would be grateful for any input.
Cheers.
High MOT emissions
Re: High MOT emissions
Mk2 with a Cat is somewhat unusual. Cats weren't really introduced till the mk3. What year is it?
It could be the cat quite possibly. The car is quite old now in all fairness though that reading is rather high
Hi Thanks for replying,
the car is an L reg "93".
Ah it's a mk3 then
Is it an SPI or an MPI engine?
What's the reg?
93 is one of the last mk3s so it might have an MPI engine
What's the reg?
Hi Alex
the cars reg is L953MYA
VOLKSWAGEN POLO COUPE GENESIS 3112 1.0 PETROL, 3 Door COUPE
This is all I can find out at the moment, when my son gets back I'll get the reg documents from him.
Not sure thats the right reg.
Its coming up as:
L953MYA is a White 1993 Nissan 100 Nx, first registered in Taunton in 1993.
Genesis was a good little car...I had one the same, but in a 1.3
Let me know once you have more info.
Its coming up as:
Hi Alex,
sorry about the delay, long day at work yesterday.
The engine is an SPI model.
Still waiting to hear from our mechanic if the car has passed with the new cat yet, he,s fitting our car in when he get the chance as he is really busy.
The reg is right, I've had the Nissan come up a few times myself.
Once again thanks for your interest,
regards
Phil
regards
Phil
No problem
Hopefully the CAT will fix the issue
If thats not right, you might have a deeper emissions issue. Cant remember if this engine had a charcoal canister or an EGR valve. It might be a bit early for that
