2013 Polo R-Line. Adding OEM Xenon
jedi-knight83
Drives: Polo R-Line, Golf GTI, Caddy TDI
Post by jedi-knight83 »
Hi again.
second question of the day.
How easy is it to upgrade from the halogen lights to OEM Xenons?
I know on my caddy for instance its a very difficult and expensive job as you have to fit 2-3 different control modules as well..
But whats the story with the 6R Polo? Is it a bit more plug code and play?
Thanks in advance.
Nathan
Re: 2013 Polo R-Line. Adding OEM Xenon
if you want to do it in compliance with the rules, you have to:
- change the BCM
- add auto leveling headlights (sensor + module)
- install headlight washers
- do some wiring
you could also do it with a relatively simple adapter that some people make. it's not as nice as the OEM way but a lot easier. also I'm not sure about the legal requirements in the UK.
