RUM4MO wrote:"FOD" yes used a lot in aerospace industries,
You hit the nail right on the head! Image
RUM4MO wrote: we have a guy that gets called FOD, but that stands for "F" off Dave, though stolen from the original use of FOD! As you might guess, he was not everyone's best friend!
:lol: ... very grateful for the explanation, I have yet to learn a lot and this is the best way for me ... thanks!!Image
When I have finished with my current modification, whatever the outcome, I will update the links on the first page of my topic.
Thanks for your patience and understanding, you guys are the best.
warder
Drives: Polo 6R 2011
Post by warder »
Hello ciclo,
I read your post:
ciclo wrote:6R0920870 C , E. BlueGT model
This instrument cluster is right for your 1.4. :wink:
and I would also change speedometer in my Polo... :twisted:
So which of this is better choice? C or E? :?:
warder wrote:Hello ciclo,
Hi warder,
I do not know what is the best option, E model is an update of C model.
iichel wrote:Image
Bad news. :evil:
It has not been possible to adapt BCM 7E0 at the VW dealer to activate "Light Assist" on my Polo 6R, according to my VW dealer, the ODIS program does not allow this option when is introduced my VIN.
I am considering alternative programs, I think it will be the best option.
Another new delay for "Light Assist" on my POLO 6R ... :P
Update the links of first page: (tigerstyle to uk-polos)
http://www.uk-polos.net/viewtopic.php?f ... 03#p459956
alexperkins
Site Admin
Post by alexperkins »
8)
alexperkins wrote:8)
That image is included in my next video :D , I hope to finish asap with the ongoing project to publish the video, but I fear it will take at least a month.
ciclo VS software, Image
CNK
Drives: 6R
Post by CNK »
I'm looking forward!
I have not yet achieved positive results, my tools are very limited, "at this moment"... the results will arrive before or after.
By the way, T73a/9, for Emergency Brake Button... (VW Up, Seat Mii...)
sudsonsundaze
Drives: GTI
Post by sudsonsundaze »
Hi Ciclo,
Wanted pick your brains on how to hardwire in dash cams. Looked at the fuse box, don't have a multimeter but thought perhaps you may know what empty one i should connect it to? I can send a pic? Its to power cameras when ignition is off, for the motion sensor when parked.( i had someone smash into my last car when parked and they just drove away, I came back to my car and saw the damage, cost me £700) so trying to prevent same from happening again. I have both front and rear cameras. I have the new 6c polo GTI. Instructions say just to wire it to the interior lights or hazards, but that seems unsafe to me and would prefer it to have its own dedicated slot! So if I get a fuse tap adapter, to connect to the uninterrupted power supply that came with camera, not sure what amp i should go for ( the camera instructions states max 250v/max 2amp) but see a lot of people use different in some cases 20amp on vids and such i have watched. Any pointers much appreciated, thanks!
Hi sudsonsundaze, sorry I have no electrical diagrams Polo 6C.
Your GTI 6C have RVC from factory, right?, so you should connect the front camera (power supply) in the same fuse (output) for RVC, the fuse value should be the same (current) if the two cameras are not active simultaneously.
iichel Image, Fuse box layout 6C :?:
sudsonsundaze
Drives: GTI
Thanks ciclo and iichel. Em, are you talking about a front camera to work with the rear view camera for parking? What i have is 2 dash cameras that i have installed myself and use but i have to hardwire it in to get the motion sensor to work when ignition is off. ( so the cameras record people or objects near/hitting your car) Not really wanting to piggy back fuses on the hazards or anything that works when ignition is off, rather it had its own place so to speak. Perhaps i will have go get access to a multimeter to check? unless you know what one(s) are safe to run off?
Locked
